Fresh built 468 BBC/TH400 Trans
Fresh 468 Big Block. I have done the cam break in and started it up to show it off a few times. It has been tuned and runs excellent.
Everything from Radiator to exhaust tips is $4500 I do have a little wiggle room but not much. I will not ship. It is still sitting in my project truck so it can be started. I will pull it once sold. Engine: 468 block 781 casting heads, large oval (fresh rebuild) stock valves Full roller rockers larger push rods Comp xe274h cam,with matching valve springs, lifters, timeing chain, ect Speed Pro pistons (9.5:1) (Wanted something that would run on pump gas easily) Full floating piston rods Steel crank Eldebrock air gap intake (powdercoated) Holly 750 cfm vac secondary carb W/electric choke D.U.I. distributor & 10mm Taylor spark plug wires in really nice looms Wrinkle finish valve covers, oil pan, timing chain cover, and breather with 4" & 5" K&N filter Full serpentine pulley set up with edelbrock high flow water pump Lokar dipstick TCI Fly wheel Very nice throttle bracket with built in return spring Hi torque mini starter. (turns it over quick!) If you were gonna put this in a Square I also have ceramic coated Sanderson BB8 headers that bolt right in as well as a full 2.5" dual exhaust with H-Pipe and Spintech prostreet mufflers. I also have a extra large 91 chevy 4 core BB radiator that has a fresh rebuild and all the shroud pieces as well as a brand new clutch fan. I have everything to drop this setup right in your square right down to the trans crossmember. Trans: TH400 2500 Stall Lokar dipstick It was built by a builder in Moore, OK that has been in the racing game for years. He has a really good rep locally. Wilson Transmission It is his street/strip version. The next strongest version had a manual valve body which is why I got this one. I have a video of it idling if you are interested ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
If you live in Oklahoma click this link |
Re: Fresh built 468 BBC/TH400 Trans
Sold
Awesome. Where did you get those valve covers and breather?
I got them thru summit
