Best tool for.....
Can you guys recommend your favorite tool(s) for cutting into painted sheet metal which may be pretty delicate or a small area? Like say, putting vents into a dash. I know a few ways to do it but I'd like to work smarter not harder and the right tools make all the difference in the world.
#2 | |
![]() Join Date: Mar 2007
Re: Best tool for.....
I tried a hole saw and it didn't go well. I had to fix my dash panel as the hole saw walked and created a bigger hole than I needed. Learn from my mistakes Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Yeah that was one option, a jig saw, but then thought of drilling several holes within the painters tape, then jigsaw, and then using a dremel to file down the remains. But that seems like a lot of work if there is a tool that easily cuts small areas.
That's another option. Basically it sounds like you are thinking about it right. It is scary as hell to cut into painted metal. That is my lesson learned...complete the fab of the build 100% before it goes to paint.
Marc
![]() Join Date: Jan 2009
Maybe a mini air saw? Cuts nice and is pretty controllable, as long as whatever youre cutting doesnt flex much.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
Ax.....no use painters tape and a small air saw with small blade. Much more control than a regular jig saw and will cut smaller radius. Dremel for really small stuff that require enlarging or smoothing. Here is the last hole I cut with my air saw. top at the magnets is radius too. It does not heat up the metal like a cutoff wheel.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
A nibbler can be good, too. There's no raised metal from the return stroke to deal with. Also, there's a type of putty that's great as a heat sink. I've used it before but I can't remember what it's called now. It's handy to have around for jobs like this.
![]() Join Date: Aug 2012
I agree with 1project2many. Look into using a nibbler and then you can use a dremel with a grinding bit to smooth the cut from the inside.
Certified Car Nut
I like to use tape and draw the pattern on top of the tape, drill small access holes and use a body saw. I believe its the same tool that OrrieG is talking about. It looks like this.
That's it BAM...
#11 | |
Just make sure you have GOOD new blades, with fine teeth.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Certified Car Nut
You are correct about the HF one, but I bought a Ingersoll Rand one after that and I never had that stop in the middle issue again.
#13 |
A drop of machine oil everytime you use an air tool helps with that problem.
#14 |
Certified Car Nut
I oil my air tools before I use them but I still had the issue with the HF air tool. I don't have that issue at all with the higher end Ingersoll Rand one. All in all the HF tool worked okay other than being a nuisance at times. I used it until it went out on me, but I did go higher end when I replaced it. I did the same with all the tools I use a lot and I used that air saw a lot.lol For projects every now and than I would get the HF one but if you are going to use it as a work horse I would step up the game.
