Old 11-20-2012, 01:04 AM   #1
rsmarr1982
rsmarr1982's Avatar
67-72 4x4 big block headers
im planning on puting a 454 in my 69 k20 . im having no luck finding headers to fit since we all know 67-72 4x4s didnt come with a big block . any one else out there done this swap what headers did you use? im think maybe 73-87 4x4 big block ones might work. im also gonna keep it manual trans will headers even work ? or will i have to go with manifolds?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 11-20-2012, 01:35 AM   #2
americanmusc1e
americanmusc1e's Avatar
Re: 67-72 4x4 big block headers
looking at my Dad's stock 1972 K20 suburban I don't see how headers can even fit with a smallblock lol..
if the motor you are going with is not too wild you might look into shorty headers rather than full-length. It might make them quite a bit easier to fit...
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-20-2012, 06:10 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a link to a page on my website showing what I did with my 454 in my 69 K20.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-21-2012, 01:18 AM   #4
rsmarr1982
rsmarr1982's Avatar
i didnt realize how much work this was gonna be ! small block maybe be the way for me to go for now. thanks
Old 11-21-2012, 10:12 AM   #5
70custom20
70custom20's Avatar
When I built my truck I was able to buy hooker super comp headers for it. I believe I paid somewhere around $350 for them (that was about 16 yrs ago) I believe you could also buy hooker comp headers as well. Unless they discontinued them, you should be able to buy the hookers.
70custom20 is offline   Reply With Quote
Old 11-23-2012, 08:34 AM   #6
birdistheword
birdistheword's Avatar
Also check the exhaust port shape. My truck I bought has a 454 in it with rectangular ports and round tube headers wich cause a bit of a nasty exhaust leak. The driver's side clears but the passenger side has a nice ground out portion for the header to clear that side. I bought the correct type of headers for it but the a bigger primary tube size so I now have to shim my engine up some and hope for the best.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 12-03-2012, 04:11 PM   #7
72BBCK20
I'm running F body BBC headers with an 86 K30 hydro clutch which I got the idea from this site. If you look closely I did need to have a 1 5/8" spacer machined to fit between the flange on the bellhousing and the slave cylinder. don't know if it changes anything but I am using the motor crossmember from the 86 K30 also.
72BBCK20 is offline   Reply With Quote
Old 12-05-2012, 01:29 AM   #8
Gobuffalo
Gobuffalo's Avatar
Sanderson has a good set.
Gobuffalo is offline   Reply With Quote
