Old 11-20-2012, 12:30 PM   #1
casey g
casey g's Avatar
Exclamation Drop trailing arms!
Has anyone else made there own drop trailing arms? I'm in the early stages of building mine. I'll post a pic of what I'm doing but I was wondering of anyone else has done it besides porter built.
casey g is offline   Reply With Quote
Old 11-20-2012, 12:50 PM   #2
jimmydean
jimmydean's Avatar
Re: Drop trailing arms!
There is at least a few folks that have done it on here.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-20-2012, 01:18 PM   #3
casey g
casey g's Avatar
here is my design. will be a 3 inch drop.
Old 11-20-2012, 01:49 PM   #4
ulakovic22
Looks cool, but where does the axle sit? On the pad in the back or in the cup you've created? I'm guessing the pad and then the cup is for added frame rail clearance when dropped? Are the bags going to mount on the TA or on the axle?
ulakovic22 is offline   Reply With Quote
Old 11-20-2012, 01:52 PM   #5
casey g
casey g's Avatar
The axle will mount on the back like normal. The springs or bags will mount in the notch. The notch is 1.5 lower the. Stock and where the mount for axle is 1.5 higher then stick. So there is the 3 inches
Old 11-20-2012, 02:23 PM   #6
ulakovic22
Makes sense, with it configured that way you should be able to run 15" wheels and not have to worry about scrub line issues, correct?
Old 11-20-2012, 02:25 PM   #7
casey g
casey g's Avatar
Um I'm not sure. But it wouldn't be as bad as running a big block. Im running 20s now so I don't have that scrub line problem
Old 11-20-2012, 03:40 PM   #8
jimmydean
jimmydean's Avatar
Wow, those look very cool. The build I was thinking of just used DOM tube with the same ends that Nate uses for his to mount to the crossmember.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 11-20-2012, 04:30 PM   #9
casey g
casey g's Avatar
Thanks man. Don't want to copy nates awesome stuff. Glad you like them. THe other piece is one of the two frame cross members that are behind the axle.
Old 11-25-2012, 11:56 PM   #10
Captainfab
60-66 Nut
What material are you planning on using Casey?
Old 11-26-2012, 12:06 AM   #11
casey g
casey g's Avatar
Not sure if I'm going to use 2x3 or 2x4. And not sure on the thickness
Old 11-26-2012, 11:34 AM   #12
casey g
casey g's Avatar
This is pic of my truck befor the 68 front clip swap
Also it sits about one inch lower in the front now. The springs were in wrong
Old 11-28-2012, 02:31 AM   #13
fastcam1
Young gun
fastcam1's Avatar
You install the drop spindles yet or you waiting for the trailling arms to be done?
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 11-28-2012, 09:41 AM   #14
casey g
casey g's Avatar
I'm going to need to wait. There is a lot that will need to be changed. Frame notch. Inner fenders need to have something done. The more I look at that pic the truck sets 2 inches lower. It doesn't rub now but it will. Might get smaller tires but that puts my Clarence that much lower. So I'm not sure what my full plan is.
Old 06-20-2013, 10:43 AM   #15
casey g
casey g's Avatar
well finally started my to build the trailing arms. there not done yet but atleast there a lot closer.
also the last pic is how my truck is setting with 2 inch blocks in the back with a 6 inch spring.
Old 06-20-2013, 10:51 AM   #16
67c10rustbuket
67c10rustbuket's Avatar
Nice work! Did you bend the bars up once the spring section was cut out? just wondering how you formed them. Any more pics of the rear of the arms?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-20-2013, 11:04 AM   #17
casey g
casey g's Avatar
there is three pieces. started as one. first was a pie cut for the pinon angle. then slid up 1.5 to get a 1.5 drop. then cut out the spring pocket so it set down 1.5. then a piece was cut to fit under the back so it was strong and looked right.
Old 06-20-2013, 11:08 AM   #18
vegadesign
vegadesign's Avatar
thats a very nifty idea, another thing iv seen is the trailing arm get z'ed
does take any of the flex or strenth out of it and it gives you alot of drop
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 06-20-2013, 11:17 AM   #19
casey g
casey g's Avatar
thanks man. took a lot of thinking for how simple they really are.
Old 06-20-2013, 11:38 AM   #20
vegadesign
vegadesign's Avatar
looks really clean too man, very nice welds and shape
i took the easy route and made 3" blocks haha
Old 06-20-2013, 11:55 AM   #21
casey g
casey g's Avatar
right now now im running two inch blocks in the back.
