11-20-2012, 12:35 PM | #1 |
Previous Owner Nightmares!
My poor old truck has been thru the P.O Ringer it seems,,not only did he cut a hole in the door for a speaker,,He Cut 2 HOLES!! And then put a speaker in the A/C vent drilling holes in the plastic,,all the wiring under the dash is ripped out and heater system in a box,,I especialy like the house hold light switch running the heater motor all or nothing! funny,,that switch is the only one that works!
11-20-2012, 12:44 PM | #2 |
Re: Previous Owner Nightmares!
wow!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-20-2012, 12:48 PM | #3 |
dam!!!!!!!!!!!!!
11-20-2012, 12:54 PM | #4 |
Well, if you can't figure out a wiring problem, just remove all the wires!! lol It's funny, looking at it from this end. Probably not so funny from your side!!
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
11-20-2012, 01:19 PM | #5 |
Rottenwood Garage Member
Musta been an electrician ....
My 72 lwb had the trans hump cut out to facilitate shifting the auto trans (converted from 3-speed). Just reach through the hole and click it into gear! My 72 SWB donor truck had the vin come back stolen after 2 years .... after registering it with the DMV, etc ... After having it checked and impounded, I had to 'buy' it again from the orig owner. Just so you know, the DMV/Tag database does not cross reference the stolen vehicle database, at least in GA. My other GMC SWB donor had a TH350 that i didn't realize had been modified ... it had the mounting tabs for the flywheel cover hacked off. Still not sure what that would accomplish? |
11-20-2012, 01:19 PM | #6 |
Old Skool Club
Don't hurt the runnin' part none.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-20-2012, 01:39 PM | #7 |
I've been down that road before. Especially when buying from older owners. I bought a truck from a guy who used nails yes nails and drywall screws and old kitchen hardware wherever he could. I wish I had pics of that truck. I bought it very cheap so wasn't so bad but I cursed the PO whenever I dug around to fix stuff. That truck ended up catching fire and burning to the ground on the highway back from a hunting trip.
Posted via Mobile Device |
11-20-2012, 03:20 PM | #8 |
Oh man...
The residential toggle switch deserves accolade. |
11-20-2012, 03:53 PM | #9 |
Divorced .....WITH KIDS
I would rewire the entire truck
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
11-20-2012, 07:07 PM | #10 |
I bought an 84 cutlass that had a spliced positive battery cable from the battery to the starter.
2 pieces of cable, an actual cable clamp, like you use on wire rope, and almost an entire roll of electrical tape as insulation. When I pulled the motor I saw this tennis ball sized lump on the starter cable and had to investigate. I guess you do what you have to to get by !! LOL !! |
11-20-2012, 07:20 PM | #11 |
Save some of the rusted drywall screws, and then give them to the old guy and tell him you thought since he seems to be so fond of using the wrong part for the job, that perhaps his surgeon may be able to use them on his next hip replacement...
11-20-2012, 07:39 PM | #12 |
I love the light switch! And I thought the little flip switch under my dash for my backup lights was bad!
11-20-2012, 07:44 PM | #13 |
X 2 or at least the cab. Then put the heater box back together.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
11-20-2012, 08:06 PM | #14 |
Well atleast you dont have to wonder if you should cut holes in the doors for speakers or not, now you just need to figure out which 4 speakers you want to buy for the doors...lol
11-21-2012, 05:19 AM | #15 |
I thought I had it bad. Sorry bro.
I think I spend two hours undoing po "fixes" every week Posted via Mobile Device |
11-21-2012, 09:24 AM | #16 |
the light switch is great after 40 some years I can only imagine what has been done too some of these trucks fortunaly.
my buddies boyertown body 67 has about ten peices of rebar welded all over each of the trailing arms.I gave him a decent set the other week that he's cleaning up for it.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-21-2012, 10:34 AM | #17 |
One of my parts trucks had a piece of a coat hanger for a throttle rod and baling wire going to the fender to tension the belt on the alternater. It is really amazing what some people will do to avoid buying the proper parts
69 Chevy 4x4 383 Power |
11-21-2012, 01:49 PM | #18 |
The PO let my truck get all rusty!
Some people...
1971 Chevy K20 350/SM465/NP205 |
11-21-2012, 02:21 PM | #19 |
Gotta love wire nuts.
11-21-2012, 08:52 PM | #20 |
I think we could all fill a book on P O problems!
In my case I think it was the 3rd P O who did most of the "restoration/modifications". The guy I bought it brom was a true truck lover who just couldnt for whatever reason keep the truck-----but the guy who drug it out of a field and did a bunch of work on it is the one (I think) who really screwed it up (translated into "cost me a bunch of money to fix"). At some point, rust issues were covered over with seam sealer and painted, making my inspection a waste of time. But, the good news is----after 4 months in the resto shop, a lot of labor, a lot of new sheetmetal--she is now rust free and a lot of time and money has been spent in trying to keep the rust away. Yeah, P O's----aint they great??!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
11-21-2012, 11:44 PM | #21 |
OI! dont get me started on PO jobs. I'm pretty sure there isnt 1 aspect of the truck that wasnt 'improved' in one way or another..lol..I personally like pulling vintage newspapers out from under bondo, and taking care of all the wire nuts. ..
11-22-2012, 12:07 AM | #22 |
Yes, newspaper, cardboard, steelwool-------------reminds me of how a bunch of reality tv shows operate---------flippers!!
11-22-2012, 11:12 AM | #23 |
I am a Referee of life.
Do a search for "Dope smoking old man".Andy has posted a lot of PO horror stories about his repairs/mods.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-22-2012, 11:43 AM | #24 |
I think you might want to keep a fire extinguisher in your truck at all times until you can figure out the wiring mess. Oh and it probably would'nt be a bad idea to disconnect the battery when it's parked. Just my .02
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
11-22-2012, 11:49 AM | #25 |
Wow!
I thought my son's truck 'Nancy' was bad. You win. Good luck with the repairs. Let us know if you need any help.
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
