Garage Built Rides
![]() Join Date: Dec 2004
Window felt
So I finally picked up a complete window felt kit (anti rattle strips, glass run channel, and division bar felt) I've never done this on these trucks. I'm not doing the vent window yet, my question is will I have to remove the vent window to put the other above mentioned pieces in? has anyone installed one of these kits before? any warnings?
Thanks!
Albuquerque, New Mexico 65 long bed, shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs |
#2 | |
Re: Window felt
On installing the divider bar seal there is (2) rivets on the lower end and the screw on the top I cut holes in the seal to let them come through so the seal would lay flat in the channel and I glue the seal to the channel. The outer window seal installed easy I glued it to. Installing the anti-rattle strips I had to bend the door window flange out so the lower window channel could pass through. Doing mine was a PITA because of the electric window One more thing I had to remove the the lower channel on the window to get the window through the anti-rattle strips just to tight. |
Re: Window felt
66Farmer - Did you remove the main glass to install the anti-rattle strips? If you didn't, would you recommend doing so or is the window down far enough that it's not in the way? Sorry if I'm high jacking this thread.
My truck ain't dead, it just smells funny. |
Garage Built Rides
Re: Window felt
Thanks so much for the reply, and the pics
![]() Hi Jack away that was my next question lol Did you take the whole window glass out for the rattle strips or just sneak them in? how hard was it to pull the vent window? Sorry so many questions thanks
![]() Join Date: May 2007
Re: Window felt
The window glass fits tight between the channel. This is how I would do it.
1) pull the vent window assembly out 2) slide the window glass off of the regulator and I would let it set in the bottom of the door 3)remove the old window channel and sweeps 4) I would put the sweeps in first as they fit behind the window channel 5) put in the new window channel 6) reinstall the window onto the regulator 7) install the new window channel on the vent window and reinstall it 8) option while it's all apart you could pull the window regulator and clean them up , clean out the inside bottom of the doors. http://67-72chevytrucks.com/vboard/s...=502124&page=3 post 56 to 61
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Re: Window felt
Great write up
James |
Garage Built Rides
Re: Window felt
Thanks so much for the list dually! I may try to tackle this next weekend. I'll keep you all posted
Re: Window felt
Yeah if you were closer I would say come on over we can get done.
#9 | |
Re: Window felt
Hi 66farmer
Where did you get the felts that run along the bottom of the window and did you have any trouble with them? Quote:
