Old 11-20-2012, 07:35 PM   #1
68_Step
Brake bleeding
I have been thinking about buying a one person brake bleeder, like the Motive power bleeder. But then I was researching brake bleeding on these forums and saw a replacement brake bleeder fitting called "Speed Bleeder". If I replace my current valves with the speed bleeder valves, do I still need to have something like the Motive Power Bleeder on hand? Do the Speed Bleeder valves have a downside?
68_Step is offline   Reply With Quote
Old 11-20-2012, 08:33 PM   #2
cdowns
cdowns's Avatar
Re: Brake bleeding
all you really need for one man brake bleeding is a cement brick// been using one for close to 50 years to do the job with no problems
Old 11-20-2012, 08:46 PM   #3
68_Step
Re: Brake bleeding
I agree, just looking to upgrade the concrete block. I have also upgraded some of my wrenches to sockets too!
Old 11-20-2012, 09:23 PM   #4
jocko
jocko's Avatar
Re: Brake bleeding
I've used both 68 step. The power bleeder was the cause of the largest most caustic mess in the history of garages....
It is very easy for it to leak when the mc is pressurized (many complaints of that very thing online, and I had all the correct brackets, etc for my mc), and once that happens, there is no avoiding trashing the driver's side of your engine compartment's paint. I'm not saying it CAN'T be done without making a mess, but I've yet to do it. As a result, this turd went into the trash can about a year ago.
Speed bleeders are nice - but they aren't exactly the be-all/end-all. Hard not to get air back into the lines when self-bleeding and you let off the pedal and go to tighten the bleeder. So, perhaps, you may want to hang onto that concrete block.
I've not found a brake bleeding tool yet that is as efficient as your buddy pumping the pedal on command. Now, i've been frustrated many times when a bud wasn't available to help, so I have tried several of the self-bleeding tools. Have yet to use a vac gun, but might try one soon since I have a major brake rebuild looming...
Would like to hear what you end up using and how it works out!
Old 11-20-2012, 09:44 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Brake bleeding
I got one of these at ma local NAPA. Just a few bucks, slip it on the bleeder and pump away. It has a check valve to prevent air from entering the bleeder. Slip it on the bleeder and pump the pedal, no helper needed.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-20-2012, 09:44 PM   #6
68_Step
Re: Brake bleeding
That hurts just to think about it! The power bleeder just dropped a couple notches in the rankings.
I just breezed over the vacuum guns in th catalogs, need to add them to the search. Thanks! Glad I kept the block...
Old 11-20-2012, 09:45 PM   #7
haminator
haminator's Avatar
Re: Brake bleeding
I've started just letting mine gravity bleed.
haminator is offline   Reply With Quote
Old 11-20-2012, 09:52 PM   #8
WadmalawJoe
WadmalawJoe's Avatar
Re: Brake bleeding
I just did the gravity bleeding about a month ago.
I connected a clear tube to the bleeder valve and ran it into a can with a inch or two of brake fluid in it, so that it couldn't suck air back in.
I cracked the bleeder valves
pumped the brakes a few times
added new brake fluid to the master
and repeated until I had a nice flow of fluid with no bubbles
closed bleeders
topped off master
took it for a test drive around the farm, all was well.
It took about 20 minutes (the bleeding)
I had replaced wheel cylinders and about half of the hard lines, which is why I think it went smoothly. When I had disconnected the lines they were full of junk/muddy looking stuff.
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 11-20-2012, 09:54 PM   #9
POS1
Re: Brake bleeding
And that's a good idea.
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 11-20-2012, 09:56 PM   #10
haminator
haminator's Avatar
Re: Brake bleeding
I don't even pump the brakes unless to get a flow going. Works on slave cyl. too.
Old 11-20-2012, 09:59 PM   #11
jeffahart
jeffahart's Avatar
Re: Brake bleeding
I bought a Phoenix Systems, and I can testify it SUCKS. Or umm... sorry this is a family channel, it's not very good! Where do you live. You can have it if I can toss it that far!
jeffahart is offline   Reply With Quote
Old 11-20-2012, 10:06 PM   #12
68_Step
Re: Brake bleeding
I cracked the bleeder valves / pumped the brakes a few times / added new brake fluid to the master and repeated until I had a nice flow of fluid with no bubbles. / closed bleeders
I hope this is not a silly question, but: Did you do all 4 corners at the same time?
Old 11-20-2012, 10:10 PM   #13
haminator
haminator's Avatar
Re: Brake bleeding
I think you could do all 4 at once. Just close one down as it starts to flow free.
Old 11-20-2012, 10:16 PM   #14
WadmalawJoe
Re: Brake bleeding
Ooops, left that out,
yes I think you can do all 4, but I did the back two then the front. Closing one wheel down when it flowed good then went to the other.
Toys/projects
Old 11-21-2012, 04:56 PM   #15
68_Step
Re: Brake bleeding
Thanks for the ideas. I think I will steer clear of the power bleeder, I make enough messes without needing any help! I think I will try gravity bleeding first and then maybe the Speed Bleeders. Thanks!
Old 11-21-2012, 05:05 PM   #16
68gmsee
Active Member
68gmsee's Avatar
Re: Brake bleeding
I've tried every technique that comes around at least once, but nothing beats an understanding wife (with patience) or a six pack and a good buddy.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-21-2012, 06:11 PM   #17
haminator
haminator's Avatar
Re: Brake bleeding
Yea the two man system is hard to beat.
