11-20-2012, 07:49 PM | #1 |
79 BBC 4x4 Headers
Hey folks, I'm looking to upgrade my headers. I got a 1979 with a 454 automatic, currently I am running some cheap flowmasters that needed some not so gentle heat/hammer massage to fit. These were meant as a temp solution and now am ready to upgrade to a good quality/fitting header.
What good header have you had success with build quality and fit. Part number or link is greatly appreciated. Thanx in advance.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
01-03-2013, 01:58 PM | #2 |
Re: 79 BBC 4x4 Headers
I have 1979 with a 350. I am running 3" long tube headers with 2 1/2" pipe, 18" glassbacks, and it sounds good. The headers are flowtech brand and I have been really impressed with them. You can just google it and find the right application. I got mine on ebay for $150
01-03-2013, 05:39 PM | #3 |
I put these . Hedman's ELITE Hedders on my 1976 GMC I ton big block. I would get them again if I needed another set. On the other hand, I just put the same headers (elite)on a 71 blazer 4x4 350 engine and I would never use them again for this application.... Terrible fit and a 4 hour install.
Posted via Mobile Device |
01-03-2013, 10:20 PM | #4 |
Thanx for the response. Funny thing, I just ordered a set of hedman elites, I hope they work as well as yours do. I found the passenger side tubes on the cheapies were hitting my front drive shaft and needed a little heat and pound action.
Currently waiting on some 781 heads that I have had reworked. So at that time I am going to hit the 454 up with a new torque cam, roller rockers, timing set and the elites. Should be a few more ponies to play with then.
01-04-2013, 09:06 PM | #5 |
I'm a big fan of Heddman headers. I just did exhaust on my '86 K30 dually with 454 and replaced the 2x4 headers with 4x4 Heddmans. Why anybody thought headers would be better than 4 wheel drive you got me, but as you note with your cheapies, interferes with front driveshaft. 2x4 preclude the use completely!
I was going to go back to manifolds, but I wanted to do exhaust myself and I couldn't find any decent pre-bent headpipes for the big block trucks. Hope the Elite's work well for you.
03-05-2014, 03:47 PM | #6 |
checking in to see how the fitment turned out. Hoping they eneded up nowhere near the spring hangers... let me know when you get a chance please. Pictures would be GREAT!
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
