What do I coat my frame with?
Hey all, I am in the process of stripping down my 67 to frame, and I'm needing a quick question answered. What should I coat the frame with? I have seen them painted, but how durable is that going to be? My 67 isnt going to be a daily driver, but in the future I dont want any regrets because I went to cheap. Now having said that, this project is on a budget, so powdercoating will probably be out of the question. I have seen a buddy use the rustoleumn truck bedliner on his frame and bottom of his cab, but we havent seen any effects past a couple months yet. I thought for $7 a can it left a pretty nice, and durable surface. Any opinions on what I should do would be GREATLY appreciated. Thanks!
Re: What do I coat my frame with?
I used an industrial (Alkyd Enamel)paint (used on tractors) from Valley Paint Manufacturing...my local paint store had it in stock and a few sheens to choose from.....best of all a gallon was 65.00.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
Moderator
![]() Join Date: May 2007
POR 15
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Jul 2012
POR15 worked great on mine. Get it good and clean with de-greaser. and they have some kind of prep process with a product called "metal ready". I got mine off of Amazon. After the POR15 I painted it with chassis black. The POR15 is not UV resistant and will "chalk" when exposed to sunlight. I typically dont park upside down but went ahead and topcoated it with chassis black for a better shine. DO NOT get POR15 on your hands. It will not come off.
Grandpa in the rustmobile...
Good topic. Im planning on sandblasting my frame suspension pieces. What is recomended for blasted metal? Ive heard por15 is for rusty frames.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
It will coat rusty metal but also clean metal if its prepped right.
About 3 quarts is enough paint unless you are talking more than one coat. POR 15 is what I used. For a daily driver Rustoleum would be fine but not from a spray can. A tractor supply outlet is another alternative.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#9 | |
![]() Join Date: Oct 2009
Longevity? That's another question. If your truck is a hardcore daily driver, maybe POR 15 is a better choice. I think HotRod C10's frame in post #2 looks VERY nice. |
If it's blasted you should etch it with self etching primer and top coat. If just cleaned up with wire wheel then any paint will do. I personally wouldn't use POR 15. It's no better than Rustoleum. Look at the MSDS sheets. ll depends on what you going to do with the truck. If daily driver all year long then no matter what you use you should apply something over the paint from the time to time. Up here in New England we use oil. Just spray that stuff all over and it seeps in everywhere. I also have used LPS 3 corrosion inhibitor. Work excellent on my 79 that I plowed with for years.
Anyone wanna recommend me some brands for etching primer paint?
Im not real sure what the plans are yet. Rebuilding the front end with drop spindles and a bigger sway bar. Like to make a nice resto mod with LS engine but well see
GM ONLY BABY!!!
Sandblasted and then powdercoated here.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#13 |
Does anyone have any pictures of their frame coated with POR 15 for a visual? Like I said, my 67 wont be a daily driver at all, but I want something that will last, and give off that nice clean look. I plan to scrape what i can off, then degrease and power wash (repeat as needed) then take a wire wheel to it.
#14 |
#15 |
http://www.vettesupply.com/products/...231050104.html
GM Reconditioning paint. Same stuff GM used from the factory, is sprayable right out of the can and can be sprayed on bare metal. |
#16 |
![]() Join Date: Feb 2007
I was happy with the POR-15. Cleaned and de-greased, then the POR-15 metal ready primer, then I just brushed it on and then top-coated it with rattle-can spray paint when the POR-15 was almost dry (finger-drag test).
#17 | |
#18 | |
#19 |
![]() Join Date: Oct 2012
i like por-15.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#20 |
Does anyone know any places or websites that carry por 15 for a decent price?
Posted via Mobile Device |
#21 |
Gone Fishing
I used kbs coating frame paint on mine. Its cheaper than por15 and looks just as good. Pics are in my build thread
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
#22 |
Moderator
POR is all priced the same. Your best bet is ebay.
#23 |
Currently Blazerless
I would love to try galvanizing on my next truck, should last a lifetime
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#24 | |
#25 |
do a google search for "polane" by sherwin williams
its industrial paint used for HD equipment. most durable chemical resistant paint i have ever shot. http://oem.sherwin-williams.com/us/e...stic/finishes/ |
| Bookmarks |
