11-20-2012, 09:54 PM | #1 |
swap 5 lug to 6 lug
how difficult is the swap im just asking is it axles and rotors is it that easy
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-20-2012, 10:15 PM | #2 |
Grandpa in the rustmobile...
Re: swap 5 lug to 6 lug
If its disc you can get aftermarket discs that are 6 lug.
For the rear, conversion axles or find a 71 72 rear
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-22-2012, 11:53 PM | #3 |
thanks
11-24-2012, 01:05 PM | #4 | |
I have done this conversion myself, on my 72-2wd Blazer. I swapped the rotors for ECE 6-bolt versions. I bought conversion axles for the rear, also from ECE. The drums I bought locally. It was a very simple and straightforwad conversion.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
