Old 11-20-2012, 10:19 PM   #1
Howitzer
POR 15 Help!!
Hi,
I've just applied my second coat of POR-15 and am going to Top Coat with Chassis Coat black.
I'm getting conflicting info. Should i let the second coat of POR tack up and then put chassis coat on? Should i let the POR dry for the night then put chassis coat on? or should i let it dry for the night and then scuff it with a scotch bright pad and then hit it with the top coat.
So confused.
Thanks.
Howitzer is offline   Reply With Quote
Old 11-20-2012, 10:41 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: POR 15 Help!!
My understanding is that you have to prime or topcoat it while it is still tacky or the topcoat will not stick to it. I would just prime it while it is tacky, then you can put whatever you want on top of that.
LockDoc
Leon
Old 11-20-2012, 10:42 PM   #3
70cst
70cst's Avatar
Re: POR 15 Help!!
I hope this helps...
Help with Por15 / Frame Paint
http://67-72chevytrucks.com/vboard/s...d.php?t=467962
Real experience with por15
http://67-72chevytrucks.com/vboard/s...d.php?t=484012
pouring down some por (15) this weekend
http://67-72chevytrucks.com/vboard/s...d.php?t=424866
First time por 15 user?
http://67-72chevytrucks.com/vboard/s...d.php?t=385556
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-20-2012, 11:03 PM   #4
Howitzer
Re: POR 15 Help!!
Thanks for the links.
Still a bit on confusion, not finding my answer in them.
I'm using the POR-15 Brand Top Coat, so do i do it while it's tacky, just like i did with the second coat of the POR-15 Base? Or can it go down once it's dry?
Old 11-21-2012, 12:32 AM   #5
cdowns
cdowns's Avatar
Re: POR 15 Help!!
i have always had excellent results by applying topcoat over POR15 while it is still tacky
if you let it dry then you must take the extra step of using thier primer and then the topcoat
