Old 11-21-2012, 12:30 AM   #1
joe1966
Exclamation 66 chevy headlight problem?
My 1966 chevy c10 2wd has some weird headlight problem. When i turn the light switch on i barely have headlights. like the left one is decent but the right is like a flickering orange glow :/ I went and changed the bulbs with new ones thinkin that would work but still it is the same. I unplugged the main light plug and cleaned it reallly really good. and plugged it back in and still the same, I also took off the grill off to rewire it all and im still having the same problem? what could it be? and clicking the high-beam switch it had no affect on the right and very little on the left. wonder what it could be?
joe1966 is offline   Reply With Quote
Old 11-21-2012, 12:41 AM   #2
oakstcustomz
oakstcustomz's Avatar
Re: 66 chevy headlight problem?
The headlight switch powers the headlights so make sure the
Red wire at switch has 12 volts atleast..... If so the blue wire
goes to the high beam selector see if it has 12.... Could be a bad
switch or headlight high beam switch but double check grounds
At headlights! Must be clean and paint free!
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 11-21-2012, 12:44 AM   #3
yelmer
The switch sometimes sticks pull out and push down on the handle sometimes it makes a better connection.
yelmer is offline   Reply With Quote
Old 11-21-2012, 12:25 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: 66 chevy headlight problem?
We've run into this several times in our garage PLUS I've seen it online numerous times: GROUND! GROUND! GROUND! You can check quickly if this is your problem and then go from there. Run a temporary ground from ground terminal going to your bulb (We do testing on passenger-side bulb since it's closer to battery.) to the negative terminal on your battery----use a good-size wire, like a 10-gauge or 12-gauge, just for testing. If you need to know which is ground-terminal, Google is your friend. If lights are noticeably brighter, then run good grounds to your bulbs. While there, you can also easily check proper terminals for adequate voltage(should be MINIMUM of 12 volts--better if greater).
HTH,
sam
*Here is a good site for wiring checks, and is more widely applicable than its "titles" may indicate...Scroll to bottom of page to look for your particular issue.
>> http://www.6066gmcguy.org/ <<
luvbowties is offline   Reply With Quote
Old 11-24-2012, 08:54 AM   #5
kieth
kieth's Avatar
After fixing the grounds, do yourself a favor and install a pair if relays....will make a world of difference....search for headlight relays......Kieth
ps I soldered a ground wire to every light housing on my truck and then installed grounding blocks to the frame . no more chasing grounds and all lights are brighter..
kieth is offline   Reply With Quote
Old 11-24-2012, 11:09 AM   #6
sigshooter
sigshooter's Avatar
Ground is the problem..... Our trucks only had a single wire coming off the battery cable to the core support that supplied ground to the body. Think about it.... the engine is mounted with rubber mounts, the body has rubber mounts to the frame, etc.
Later in 1966 they started adding ground straps from the engine to the firewall, but people took these off and threw them away when the did repairs.
I found these on 95-96 explorers and added them to my truck since they just slip on. I added them everywhere, grounded cab to frame, bed to frame, core support to frame..... ALL my lights are brighter including dash lights, and the amp meter is more stable doesn't bounce around as much.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
