Old 11-21-2012, 02:29 AM   #1
mexlokote
mexlokote's Avatar
carb questions
i ordered a carb for my truck its a 2bbl rochester
and the only difference is something i spotted if u can see in the pic im not sure
what it is or whats it for, or where it goes connected there
my old carb does not have that
anyone know?
also on second picture something goes connected there? where can i find this wire at? whats it for?
mexlokote is offline   Reply With Quote
Old 11-21-2012, 09:05 AM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: carb questions
I think that hooks to A/C compressor so when it kicks on it increases idle speed by kicking out to throttle linkage....but maybe someone else here familiar with 2V carbs can shed some light.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-21-2012, 09:56 AM   #3
Dead Parrot
Re: carb questions
If I read the id number in the first pic correctly as 17059762, you have a Varajet II Model E2SE. I think the 3 pin connector is for a throttle position sensor. I agree with 88Jimmy4x4 on the 2nd one. I think what you have is off of an early computer controlled vehicle.
Dead Parrot is offline   Reply With Quote
Old 11-21-2012, 03:03 PM   #4
mexlokote
mexlokote's Avatar
Re: carb questions
my old carb is not a computer controlled car, and it has that connection that goes to the a/c, jusy wasnt hooked up, but now i hooked it up thanks guys,
still have problems with the 3 pin connector, would i be able to wire it up or will do fine without it??
Old 11-21-2012, 03:44 PM   #5
beamn7
Re: carb questions
Correct, the single wire is the ISC (Idle Speed Compensator) and ups the idle when the A/C is on. The 3 prong connector is for a TPS (Throttle Position Sensor) meaning the carb is for a ECM equipped truck. It will work fine disconnected.
beamn7 is offline   Reply With Quote
Old 11-21-2012, 03:46 PM   #6
mexlokote
mexlokote's Avatar
Re: carb questions
thank you!
