Old 11-21-2012, 04:32 AM   #1
Rifter_Chevy
Bulb socket question
Ok, im replacing all the wiring in my truck, literally all of it from headlights to tail lights.
Im going to replace all bulb sockets while im at it but i need to know which sockets to buy.
I have a 1984 pickup, i know the tail/brake/turn lights are 2057's i know the front sidemarkers and rear corner markers are all 194 wedge bulbs.
What i need to know is what are the front turn signal bulbs?
I think they were single 2057's per side however i have switched my front end to a newer bodystlye and now have the dual signals/markers per side not the single bulbs the stock front end had. I know i had to cut the original single bulb base's at the tabs to get it to fit into the dual bulb fixture, i have been running with only a single bulb per side and this is part of why im buying the proper bases and going to real dual bulbs per side.
what is the correct base for the dual bulb fixtures? is it a 3057?
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case
Rifter_Chevy is offline   Reply With Quote
Old 11-21-2012, 05:12 AM   #2
earnhardtgm3
earnhardtgm3's Avatar
Re: Bulb socket question
High & low beam headlamp
H6054
Parking light
2057A
Front turn signal
2057A
Rear turn signal
2057
Tail light
2057
Stop light
2057
License plate
67
Back up light
1156
Front sidemarker
168
Dome light
211-2
Step/Courtesy light
1004
Instrument-general
168
Hi-beam indicator
168
www.sylvania.com
1977 Chevrolet Scottsdale:
1979 Camaro Z2/8
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 11-21-2012, 10:48 AM   #3
Ski-me
Ski-me's Avatar
For your instrument bulbs, I think the 168's are brighter than the 194's......go brighter!
If you are feeling lucky, take the whole cluster out, clean it real good, and hit it with some choke paint. It will reflect better and make your dash gauges look a lot brighter!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 11-21-2012, 11:20 AM   #4
Rifter_Chevy
maybe i wasnt clear, im talking about the turn signal/markers on the front grill, below the headlights, not the cluster.
I think they are 3057 on the dual bulb per side front end but need verification on that if possible.
