Old 11-21-2012, 12:44 PM   #1
el_diablo
49 1/2 ton, S10 frame- wheels?
I apologize if this has been asked before, but.. What size wheels are you guys running? How wide can you fit? What offsets?
My '49 is on a '86 S10 frame.
'49 Chevy 5window/S-10 frame. LS 408ci/4l80
'71 Chevy C10- Sold a long time ago.
el_diablo is offline   Reply With Quote
Old 11-21-2012, 07:05 PM   #2
BlueJeep
BlueJeep's Avatar
Re: 49 1/2 ton, S10 frame- wheels?
Stock 15x7 s10 wheels, 3.75ish backspacing, 235/75R15 tires.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-21-2012, 07:15 PM   #3
mr48chev
mr48chev's Avatar
One of the best parts about an S-10 swap is that you can run some really deep reverse wheels and get away with it without having the fenders rub the tires.
A lot of the guys who aren't running reverse or wider rims and bigger tires run spacers to move the wheels out in the wheel well.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 11-22-2012, 07:16 PM   #4
98layinframe
98layinframe's Avatar
Out back I have a 4x4 s10 rearend with 18x9.5" torque thrust II's running a 3.75" backspace and they clear the fender lips perfectly. But with a wide wheel and wide 275 series tire it requires a small wheel tub in the bed side.
I slapped my wheels on a buddies truck running the same 4x4 s10 rear but he has 1" thick adapters on and so the tires wouldn't fully tuck on a bagged truck without rubbing the fenders, but would of worked great on a static height truck... without any need for the wheel tubs in the bed sides.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 11-22-2012, 08:20 PM   #5
S10Fan
Old Heap Driver
I knew I'd be running hubcaps on mine so I went with wheels from Circle Racing. 15X7 on all 4 corners with 2" BS on the front and 1" BS on the rear. The racing wheels required use of 5/8 wheel studs so all the hubs and axles had to be drilled for the much larger studs. I also had to buy an additional wheel for a spare, 1" BS.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-22-2012, 08:29 PM   #6
S10Fan
Old Heap Driver
I forgot to add.....
Circle had a bunch of wheels in their "clearance" section, 2 of my wheels are black powder coat, 1 is chrome, 1 bare steel, I averaged 35.00 each for my setup.
Bryan
Old 11-26-2012, 10:22 AM   #7
el_diablo
Thanks guys. I want to run a 15x10 with 315/60 drag radials. (about 29.5x10.5") Hopefully I can get them to fit without doing anything crazy.
