Usable torque to the ground
OK, I made a spread sheet that shows most engines, their spec's, then calculated all the needed stuff to show mph at a given rpm, with different axle ratios, and tire diameters........If anyone needs to use this feel free to pm me or call....for explanations. Kieth 918-446-2245
I will finish this later, I do not know how to copy from excell to this forum: here is one for 30" diameter wheels and tires: ohn well it did not work....Just call me and I need to know what tire diameter you have in inches what rear axle ratio what transmission Then I will e mail you a spreadsheet that shows torque to the ground for 230, 250, 292, 283, 327, 350,350tbi with your specs. this will make selecting a transmission, engine, tire size combo make a lot more sense. Kieth |
