Gas Tank Swap
Will a 69 Chevelle gas tank work for a under bed relocation on a 69 C-10??
![]() Join Date: Mar 2011
Re: Gas Tank Swap
Take the measurements on your tank. Then go to ebay, do a search for a 69 camaro tank-------compare the measurements. I think the chevelle tank might be too wide--where the camaro tank will definitely work (many are using the camaro tank with the filler behind a drop down license plate.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
Re: Gas Tank Swap
I did agas tank swap using a 78 chevy van small tank,and it has worked out great.It is a side fill,so I grafted a door on the side of the bed.Couldnt use flip down at license plate as have a trailer hitch behind plate.Van gas tank is compatible with the truck gas guage.Have to remove crossmembers for spare tire and make new ones for the tank.
Re: Gas Tank Swap
Ok...will the camaro tank allow me to set it up for an LT1?
72 Chevy C10 350 Flame Orange |
Re: Gas Tank Swap
1985 40 gal suburban tank installed in a 1971 4x4 long bed,,works *****en! Er,works realy good?? lol
http://67-72chevytrucks.com/vboard/s...d.php?t=551269 |
Re: Gas Tank Swap
don't mean to hijack but has anyone ever tried to use an f150 rear tank in a 67-72 chevy
![]() Join Date: May 2011
Re: Gas Tank Swap
I am going to try a 70 chevelle gas tank, a 67-72 chevytrucks group member on facebook did the install in his truck and he mounted it flush with the frame, where the camaro tank i have seen members had to put 3 inch spacers between frame and tank. I ordered my tank from rockauto for $343 with fuel pump inside tank. they have a regular chevelle tank for $115 and a camaro tank for $85
Posted via Mobile Device |
![]() Join Date: Aug 2007
Re: Gas Tank Swap
Looks like the Chevelle tank will work with less modification....
Re: Gas Tank Swap
That's the one I was talking about, the only problem I might run into is my truck is short wheel base, might be a very tight fit
Posted via Mobile Device Posted via Mobile Device |
Re: Gas Tank Swap
That Looks awful low to the ground to me?? Is there a skid plate under that?
edited by staff |
Re: Gas Tank Swap
I don't think it would be any lower than a blazer tank..... I would like to see a rear shot though....
Re: Gas Tank Swap
It's 7 3/4" at its deepest
