Old 11-21-2012, 03:45 PM   #1
jimminee2000
Anyone using the blazer tanks with LT1?
I have an LT1 and T56 to drop in and trying to figure out a cheap solution on my fuel problem.
If not, anyone have any good ideas that you have used to get it out of the cab for a decent price?
James
PS Just bought a 72 C10 LWB.
72 Chevy C10
350 Flame Orange
jimminee2000 is offline   Reply With Quote
Old 11-21-2012, 04:00 PM   #2
True 67
Re: Anyone using the blazer tanks with LT1?
great question as I have a LT1 with a 4l60e waiting to be dropped in..I was thinkning of going with theBlazer tank myself.
True
True 67 is offline   Reply With Quote
Old 11-21-2012, 08:17 PM   #3
TchncnDen
I used a blazer tank and made my own in tank fuel pump for my lsx, it should work fine for an lt1 as long as you use the right pump/regulator for the job. Total cost with tank, pump, lines about $300. It works great!
http://67-72chevytrucks.com/vboard/s...d.php?t=518036
TchncnDen is offline   Reply With Quote
Old 11-21-2012, 10:23 PM   #4
jimminee2000
How did you do your lines? Just the regular fuel line material or out of a truck or Fbody?
72 Chevy C10
350 Flame Orange
Old 11-21-2012, 11:16 PM   #5
TchncnDen
I used a 25' coil of 3/8" steel line for the feed and a 25' coil of 5/16" steel line for the return connected with high pressure fuel injection rubber hose at the tank and engine. You can buy a bender at any parts store or harbor freight. Make sure you use submersible hose to connect the fuel pump to the line in the tank. It is very expensive but regular fuel line will turn to jelly fast. Give me a couple of days and I'll do a how to.
Old 11-21-2012, 11:55 PM   #6
jimminee2000
Hell ya. I would appreciate that. Been searching how to's for a week now.
Thanks Bro.
72 Chevy C10
350 Flame Orange
Old 11-24-2012, 01:49 PM   #7
TchncnDen
Write up is done. If you have any questions please reply to that thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=553299
Old 11-24-2012, 02:53 PM   #8
67cheby
67cheby
67cheby's Avatar
check out the drop in pumps from (www.tanksinc.com) i used one in my tank very nice setup !
67cheby is offline   Reply With Quote
Old 11-24-2012, 08:18 PM   #9
TchncnDen
I modeled the one I made after the tanks inc one mentioned above. The reason I didn't just buy one of those is that they only fit a 10" tank and the blazer tank is 14", plus those line fittings sit up way too high. I'm sure it could be modified to work with a deeper tank, but I decided if I was going to modify I might as well just make my own. If you're using a tank 10" or less and you have room on top the tanks inc one is probably well worth the money just in time saved.
