Old 11-21-2012, 07:22 PM   #1
gabe2000
large turnning clearance???
I got my truck running but to make turns it takes a very large circle turn? Any ideas???
gabe2000 is offline   Reply With Quote
Old 11-21-2012, 08:21 PM   #2
DesertCat
DesertCat's Avatar
Re: large turnning clearance???
Make it a 1/4 miler? These trucks were meant for work and this is but another one of the charming things about them
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 11-21-2012, 08:26 PM   #3
hemifalcon
is the radius the same approximately from the left to right? Meaning--is it the same number of turns from lock-to-lock of the steering wheel?
hemifalcon is offline   Reply With Quote
Old 11-21-2012, 08:43 PM   #4
Reyals Bemus
Interesting... I always found my '64 C10 to have a super tight turning radius. I love it.
Reyals Bemus is offline   Reply With Quote
Old 11-21-2012, 08:56 PM   #5
McCoyAZ
McCoyAZ's Avatar
I feel your pain.
I have to turn wide or I pull in, then back up and take a 2nd stab at getting in a parking space.
McCoyAZ is offline   Reply With Quote
Old 11-21-2012, 11:08 PM   #6
donthekawguy
donthekawguy's Avatar
The gears are welded in my rear end so not only do I have the wide turning radius but it pushes the front wheels while turning. Almost feels like a 4x4 turning on dry pavement. Another reason I need a new rear end.
66 shorty
donthekawguy is offline   Reply With Quote
Old 11-22-2012, 12:02 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
As mention above, check if the turning radius is the same left and right.
66 C20 Service Truck:
Old 11-22-2012, 12:12 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
I'd suggest jacking up the front end and have someone else turn the wheels from lock to lock and see if anything is binding. If the tires are too big or the wheels have the wrong offset they could be hitting the frame or body work. The steering linkage or the stops on the spindles could also be bent limiting travel.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-22-2012, 12:50 AM   #9
contagious102
contagious102's Avatar
Not very safe, that's going to leave you on the side of the road.!! Your right need to replace that SOON.!!!May even have a axle come out.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 11-22-2012, 07:32 AM   #10
tincan1966
tincan1966's Avatar
Have you had the alignment checked? Improper toe in can cause alot of issues.
tincan1966 is offline   Reply With Quote
Old 11-22-2012, 08:29 AM   #11
luvbowties
luvbowties's Avatar
Question Re: large turnning clearance???
Hemifalcon and LostMy65 both asked an important question. They have a specific reason for knowing that answer...and they may have some good advice for you if they learn the answer.
luvbowties is offline   Reply With Quote
Old 11-22-2012, 04:08 PM   #12
donthekawguy
Yeah i'm searching foir rear end and now that the weather has turned i hardly drive the truck. i hope to get it done by spring.
66 shorty
Old 11-22-2012, 06:39 PM   #13
FetchMeAPepsi
FetchMeAPepsi's Avatar
My 4x4 is like that. I can't turn around in my cul-de-sac with her. I have to back up and pull a three point turn to get around it.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 11-23-2012, 07:19 PM   #14
gabe2000
thx for the input. imagine its normal on these old truck. I want to start another thread......conventional steering system vs. rack-n-pione steering system. Maybe rack-n-pin system is better and tighter turning clearance.... thx
Old 11-23-2012, 10:05 PM   #15
ChrisDollins
ChrisDollins's Avatar
Yea, something may be wrong. My 66 seems to have a pretty tight turning radius.
Chris
ChrisDollins is offline   Reply With Quote
Old 11-24-2012, 12:34 AM   #16
Rooster's 67
Rooster's 67's Avatar
Try actually measuring the turing radius and let us know what it is. then we can tell ya for sure if it is normal or out of specs.
Oh and we will need to know the wheel base.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 11-24-2012, 02:25 AM   #17
luvbowties
luvbowties's Avatar
HEY, GABE! We need to know 3 things to determine whether just something merely needs adjusting on your truck or if there is something critically wrong with your truck.
First:Is the turning radius the same when turning left as when turning right? Try turning around in a big parking lot--first to left and then to right. Does it turn around in a smaller circle one way than the other? If so, which way is the radius shorter?
*NOTE: When doing the following tasks, turn the steering whl. such that front wheels are straight ahead. Use 2 pieces of masking tape, each about 3-4 inches long: place one of them along/around the steering wheel collar-adapter; place the other along/around the steering wheel's center hub, running parallel and kinda close to the first piece. Use a pen or pencil and draw a straight line, on the tape, at 90-degree angles up-and-down so that the marked line "crosses over" the gap between the 2 strips of tape. This mark(actually it becomes 2 marks as soon as steer. whl. is turned a tad) gives you a good reference as to where you started from, and how far your marks are away from lining back up when wheel reaches its stop.*
Second: When sitting still with wheels pointing straight ahead, turn the steering wheel clockwise until it will turn no further. Now release the steering wheel slowly. How many turns did it take, including any partial turn, to reach its stop? Like, "1 and 3/4 turns" or "2 and 1/4 turns" or "a tad less than 2 and 1/2 turns". Imagine a clock and use the 12-o'clock, 3 o'clock, 6-o'clock, and 9-o'clock positions as reference.
Third: When sitting still with wheels pointing straight ahead, turn the steering wheel counter-clockwise until it will turn no further. Now release the steering wheel slowly. As in the Second question above, how many turns did it take, including any partial turns to reach its stop?
If we know this information, we may be able to help you cure the problem quite easily and inexpensively. Hopefully, that will be the case.
sam
Old 11-24-2012, 01:01 PM   #18
hemifalcon
A couple of ideas have been offered--need the original poster to try a couple of the simple tests to determine his number of turns from center to full-lock left, and from center to full-lock right..
The fact that you have a welded rear end is even more of an issue than if you had a posi or locker rear end.. That in essence is only wanting your truck to go straight as opposed to letting the rear end "slip".. That may be a contributor to the issue of course..
Old 11-24-2012, 01:49 PM   #19
tincan1966
tincan1966's Avatar
Rack and pinion steering will not make the truck turn any tighter- it's only going to turn as sharp as the steering stops will let it, whether it is manual, power or rack and pinion.
Old 11-24-2012, 03:23 PM   #20
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I looked up the turning radius in the 1963 Chevrolet Truck Data Book.
C14 115" wheelbase is 22.9 ft. radius
C15 127" wheelbase is 23.5 ft.
