11-21-2012, 09:12 PM | #1 |
Another Day, Another Dollar
metallic "PING" when truck drops into gear
Hey,
sometimes when i drop my truck into gear (often on an incline) there is a loud high-pitch PING noise coming from somewhere in the undercarrige. It almost sounds like someone is hitting a pan with a hammer. NP203, TH 400, 454 anybody else encountered this? Trans was rebuilt not very long ago because the reverse band ripped out of the casting, casting was replaced.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
11-21-2012, 09:26 PM | #2 |
Re: metallic "PING" when truck drops into gear
Hmm, not sure about a "pang" noise but mine had a rather distinctive "clunk"ish noise because my u-joints were worn and loose. New u-joints fixed that problem.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
11-21-2012, 09:29 PM | #3 |
Change your octane and see if there is a diffrence
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-21-2012, 09:44 PM | #4 |
its not a ping from the engine, its somewhere in the driveline
11-21-2012, 09:49 PM | #5 |
Yup, 2nd that...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
11-21-2012, 09:55 PM | #6 |
It can resonate in the exhaust too. Maybe check your flywheel and see if its cracked were it mounts to the crank. A reverse band ripping out sounds violent.
Check rubber mounts and such as well they rip apart easily Posted via Mobile Device
11-21-2012, 10:08 PM | #7 |
What Hump?
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
11-21-2012, 10:14 PM | #8 |
I know the pieces fit
11-21-2012, 10:18 PM | #9 |
my u-joint that lost some bearins didnt ping, it make a clunk. did it when i put it in got on the gas, let off, shifted and anything that would move the driveshaft. i would look for cracks in the flex plate
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
11-21-2012, 11:19 PM | #10 |
how big is the view hole going to be on my bell housing?
11-21-2012, 11:42 PM | #11 |
Should be an inspection cover that comes off with four screws. Very easy to see in there then
11-21-2012, 11:45 PM | #12 |
thanks, I'll have a look tomorrow
11-22-2012, 01:39 AM | #13 |
Mine does it occasionally when the truck goes into reverse. Definitely sounds like its coming from the flex plate or converter area. Like rapping the flex plate with a ball peen hammer.
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
11-22-2012, 02:33 AM | #14 |
Sounds like you have the same thing as me Hulk, I'll let you know what i see tomorrow
11-22-2012, 03:30 AM | #15 |
When parking on incline, set parking brake while holding foot on brake, THEN shift to P. Next time you go to drive away put it in gear THEN release the parking brake...
I bet the noise you hear is the park pawl in the transmission screaming in protest at the lack of parking brake usage.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
11-22-2012, 03:35 AM | #16 | |
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play |
11-22-2012, 01:27 PM | #17 |
thanks chevybuilder, the case has been converted to part time but i'dd definitly take a look
11-22-2012, 07:03 PM | #18 |
okay, after crawling around for a bit it seems like the noise is coming from the front half of my T case.
If i grab the front driveshaft and give it a quick hard spin I hear the 'DONGGGG". This is strange because the front driveshaft has rotational slop and the rear doesn't even flinch. If the T case is in neutral this doesn't happen. How much slop (if any) as an np203 supposed to have? The front moves back and forth, the rear does not. I know this is a chain driven case and I am wondering if maybe the chain has had it? What kinda T case is in your truck Hulk Will Smash?
11-23-2012, 02:10 AM | #19 | |
11-23-2012, 03:04 AM | #20 |
there are some funky support bars under there for sure! I'm pretty sure there are 2 that go to the t case, not sure about motor mounts though. I should also have mentioned that this truck is a k20
11-23-2012, 05:25 PM | #21 |
78K & 79C Jimmys
my 78 was a rear u joint looked fine too the sound seems to carry
has two bars run from the tcase/ fwd the 88 has a bar from the transfer to the pass side bell housing bolt and this is it in the 79(78 didn't have it,has the holes )
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-24-2012, 04:21 AM | #22 |
Yup... I worked on a K10 80 something but those bars were wierd. i never seen anything like it. 700r4 with the chain driven factory T case. someone blew the 305 in it, and the we put one in it for an old ex friend of mine that i dislike, and he blew the new engine up. but i kept the old 305 bare block and 416 casting heads for payment . Any ways this one had some triangle looking plates in between the block and mounts, we reused them. they went from engine to bottom of the tranny near the dust cover or w.e that thing is
11-24-2012, 08:41 PM | #23 | |
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
11-24-2012, 09:57 PM | #24 |
It definitely has nothing to do with the parking pawl
11-24-2012, 10:37 PM | #25 |
for a parking pawl, i have slammed my TH350 in park on accident, from 20 mph to a dead stop, it was on rocks but still, should of ripped my park out or atleast made the same metalic ping he is hearing. something wierd is happening. id check the front drive shaft and yokes. if those are fine, dig into the P203. If you have had gears, your probably gonna want them again. make sure if you do a nother chain drive, throw some tacky wheel bearing grease in a cast iron frying pan, throw it on a wood stove or grill and lay the new chain in it. or soak it in motor oil for a week, always does the trick getting the lube in the right spots for break in procedures. Ive done this with timing chains, learned it off my uncle, what a wierd way of doing things
