Old 11-21-2012, 10:10 PM   #1
dukcaln
dukcaln's Avatar
drive line/u-joint help
so I swapped motors and transmissions this week. I ditched the TH350 and replaced with a TH400. Same size motor, sb350. I found a complete drive line out of a 72 that had a factory TH400 and figured it will match right up.Which it did other than the u-joints on the factory TH400 are larger than the ones on mine that I removed.
So the situation is the rear end has the smaller spline for the smaller u-joint. I was told napa auto sales a u-joint that has the two sizes built into one u-joint. Anybody ever done this?
I thought I might be able to split the drive lines and use the back half of mine with the front of the factory th400 section but it looks like the spline with the carrier bearings are different?
Hope I am clear with waht I am trying to explain without pics
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 11-21-2012, 10:28 PM   #2
mixermike
mixermike's Avatar
Re: drive line/u-joint help
I believe they are called a combination joint....I have one on in my 57 chev truck. My rear u joint is 2 different sizes because I have a mustang rearend under it.
mixermike is offline   Reply With Quote
Old 11-21-2012, 11:00 PM   #3
dukcaln
dukcaln's Avatar
combination u-joint, ok thats a start, we dropped it off at the local napa auto parts/machine shop in hopes they can match it.... anybody know the standars c10 and c20 and or small block th350 vs th400 size. long bed
SOLD 1972 chevy c10
Old 11-21-2012, 11:03 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Some places also call them a "Jump Joint".
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-21-2012, 11:09 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you have both U joints out,you should be able to measure them and cross in a U joint manufacturers data.The parts store should be able to do it EZ.If they can't,look for an old school parts guy.The other place to find them is in a 4X4 shop.They do axle swaps all the time and run into the same issue.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-22-2012, 12:22 AM   #6
dukcaln
dukcaln's Avatar
om thanks..... I was hoping someone had the standard u-joint size for the rear u-joint on a th350 drive shaft vs the th400 shaft... the th350 shaft is a smaller ujoint compared to the th400 shaft.... is the ujoint on the th350 shaft a 1310?
SOLD 1972 chevy c10
Old 11-22-2012, 01:22 AM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
You probably need a 1310 to 1330 conversion joint. I'm sure you can find a decent quality neapco or spicer made joint someplace besides your local auto supply. If not try online, precision and house brands SUCK!
You may be better off taking your shaft to a driveline shop to have it checked out. It may need more work than you know. Have them check the joints, support bearing, straightness and ballance.
I've been building driveshafts for about 5 years. I don't know everything but I know way too much about driveshafts.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-22-2012, 02:56 AM   #8
dukcaln
dukcaln's Avatar
brad, I have been searching the internet all night and came to the conclusion I need either the 1310-1330 or 1310-1350. But it seems the 1350 were 14 bolt rear ends and more likley the combo is 1310-1330. However, the drive line I picked up is a complete driveline from tail to shaft from a 67-72 long bed with th400, so its hard to say if its 1330 or 1350, but at least I am pretty positive its one or the other.... napa has them in stock in my town, the precision PUJ353 premium universal 1310-1330 and or the PUJ348 1310-1350.
thank you. I figured somebody on this board has done the th350 to a th400 swap and had to do the drive line swap using a driveline from a 67-72 that had the factory th400....
SOLD 1972 chevy c10
Old 11-22-2012, 05:34 AM   #9
huahuamick
Think I may be in love with this
huahuamick is offline   Reply With Quote
Old 11-22-2012, 05:56 AM   #10
jjzepplin
jjzepplin's Avatar
I am doing this swap too. I went to Napa and got the 1310-1350 and it was the right size on one end but the caps were too big on the other. My old u joint was pretty new so I took two caps off it and put them on the new joint and boom there you go. So I think 1310=1330 is the one. However I am not impressed with the quality of the new joint so it will be replaced with a spicer or neapco. The new caps were loose. All of them. Go figure. Put the old caps on the new joint and they were much better than the new ones. Never again!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-22-2012, 11:22 AM   #11
mixermike
mixermike's Avatar
I agree with brad,the percission joints suck....get neapco if you can
Old 11-22-2012, 01:31 PM   #12
dukcaln
dukcaln's Avatar
thanks all, the precisision will be to get here going and on the road, I will swap to a better u joint as mentioned...... seems the choice will most likley be the 1310/1330.... they have the driveline at the shop so I am sure it will be matched... dand Holiday today and all will delay a coiuple days... but hope she is back and running by Monday!
SOLD 1972 chevy c10
Old 11-22-2012, 10:09 PM   #13
brad_man_72
the boat guy
1310 and 1330 have the same size caps.
1330 and 1350 are the same width.
For those planning to swap out your precision joints keep the box, they have a lifetime warranty so you can go get your money back from the parts store.
It also helps to have a shop install the joints, someone experienced will be able to easily get the play out of a good ujoint wich will make the joint last longer and the ballance will be more accurate.
Old 11-27-2012, 12:10 AM   #14
dukcaln
dukcaln's Avatar
so got it figured out and the drive shaft is in... turns out I needed a 1310/1350 combination ujoint
now we hope to fire the ole truck back up tomorrow
SOLD 1972 chevy c10
Old 11-27-2012, 08:49 AM   #15
mixermike
mixermike's Avatar
Good to hear
