Old 11-22-2012, 03:25 PM   #1
savatreatabvr
savatreatabvr's Avatar
Correct 454 Exhaust Pipe Diameter?
My mid 70's 454 has massive 3" pipes all the way to the back, what is the factory OEM pipe diameter? If it's not 3", could the pipes being to large hurt my performance?
savatreatabvr is offline   Reply With Quote
Old 11-22-2012, 03:34 PM   #2
Firebirdjones
Re: Correct 454 Exhaust Pipe Diameter?
The stock diameter on my 79 454 were 2 1/2".
I've run dual 3" on mine for years with the 454 (now a 502) with long tube headers and quality mufflers. Works great.
Firebirdjones is offline   Reply With Quote
Old 11-22-2012, 03:42 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Your fine. Your exhaust manifolds are killing more power at this point
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-22-2012, 03:52 PM   #4
Firebirdjones
You still have manifolds?
Old 11-22-2012, 05:25 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My r30 TBI 454 truck has factory 3 inch single exhaust.
Old 11-22-2012, 11:23 PM   #6
savatreatabvr
LOL, yep I've still got stock exhaust manifolds! I do plan on getting headers one of these days but right now I'm just trying to keep it running as good as I can for as cheap as I can! Anybody got a cheap set of big block headers laying around?
Old 11-24-2012, 08:45 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
don't know if you have these but some grinding may help keep it cheap and flow better
i always find the sound gets louder/better
smooth out the flow has gotta help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-24-2012, 10:27 AM   #8
Firebirdjones
If you are really bent (or rule restricted) to keep the stock manifolds, after initially porting on them like Motornut mentioned above, I send them out to be extrude honed. Keeps that stock appearance and picks up several HP
