1972 402 Napa engine rebuild kit
I have what looks like a complete rebuild kit I received with a truck I purchased.
The pistons are .30 over and comes with the following: Aluminum pistons Cam/lifters/bearings perfect circle rings Dana rockers and pushrods Federal Mogul Made in USA rod and main bearings timing chain and sprockets freeze plugs all gaskets unopened oil pump If you are looking for a factory stock 402 rebuild kit, this is an inexpensive way to start. Not sure of the age, but most components look like they are made in the good ole USA and are not discolored, surface rusted etc! Even if you are cleaning up or freshening up a 402, the price of gaskets and an oil pump begin to add up. This box is very heavy. $300 shipped to conus. I can provide pictures if there is interest. Trades? |
Truckin' Krazy
![]() Join Date: May 2000
Re: 1972 402 Napa engine rebuild kit
Hi John, what are the specs on the bearings std or ? & how about a cam # or specs.
What parts are you looking for? Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Tom,
I need to get the specs from Napa. I am sure I will need to get them the part numbers and have them cross reference. The number on the kit box is 284-1249. I could use a tach dash, rear fleetside sport bumper brackets,tilt, Parchment door panels with our without scroll as they will be covered, SB AC brackets with bolts, 4x4 exhaust manifolds. |
Rod and main bearings are standard size.
Cam: Intake/Exhaust Cam lift .234 Intake valve lift .398 Exhaust valve lift .398 Overlap 57 Intake Duration 286 Exh duration 286 SAE int duration 270 ext duration 270 The spec sheet is attached, but you may need to download. |
Truckin' Krazy
John, don't want to hold up your sale, I have 2 crankshafts already ground at 30/30, looking for something to go with that.
Heck of a price for someone though. If you didn't find some one to buy outright, I would trade an RV tilt in great shape & a set of rear 4x4 sport bumper brackets aftermarket new. Thanks, Tom
Truckin' Krazy
John, will take it for $300 shipped
Let me know how to pay Thanks Tom Posted via Mobile Device
Thanks Tom,
PM your address and I will send out. After you receive it, send me a check so I can avoid PP fees. I will double box it or may even send in two boxes because of the weight. John |
Truckin' Krazy
John, PM sent.
Thanks, Tom
