11-22-2012, 08:48 PM | #1 |
Which way do you turn gas lock ring?
Needing to pull out my gas tank to POR 15 the floor, dynamat.. etc... and I was banging away with a hammer and brass punch but the ring won't budge... Just to make sure I am banging in the right direction, which way takes it off?
Thanks guys! Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
11-22-2012, 10:17 PM | #2 |
Active Member
Re: Which way do you turn gas lock ring?
If you look very carefully you will notice that the sending unit has stops. Just go the opposite way. Counterclockwise is always the removal procedure.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-22-2012, 10:19 PM | #3 |
Active Member
Forgot to mention... sometimes they're hard to remove. Might want to spray some WD40 and just keep tapping all the way around.
11-22-2012, 11:23 PM | #4 |
I also go around them in sequence, tapping each one a couple of times and then move to the next one.
11-23-2012, 07:53 AM | #5 |
1969 Custom 30 wrecker
Righty tighty, lefty loosie. Say that a few times and you'll never forget!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
