Old 11-22-2012, 10:01 PM   #1
68_-c\10
68_-c\10's Avatar
68 to 78 rear axle swap
Anyone know if the axles in a 78 c10 are the same length as a 68 c10? Im wanting to do a 5 lug conversion and I have a 78 donor truck
68_-c\10 is offline   Reply With Quote
Old 11-23-2012, 04:58 AM   #2
c10srule
c10srule's Avatar
Re: 68 to 78 rear axle swap
the 68 is a little narrower, but in 70 they went to a wider axle that is exactly the same width as the 78 axle so the width will be fine as long as your talking about the whole assembly, the shafts themselves wont interchange in the housings, youll have to do some modifying on the shock mounts and perches, i personally like the wider axles because it gives it more of a hot rod look but the narrower axles let you tuck the wheels and tires better, but now days you can get a lot of different wheel back spacings to fit wheels and tires how you like them for the look youre after
c10srule is offline   Reply With Quote
