11-22-2012, 10:49 PM | #1 |
How well can it ride and steer? Cpp
On my 67, I'm considering Cpp products. I was gonna do a whole front end rebuild kit,full disc brake kit, every body mount and bushings replaced front and rear,and 5/7 drop using front and rear sway bars and upgraded trac bar. Can anyone give me a comparison of how well it will ride and steer vs newer trucks? If I pay about 3500$ for parts,I'd expect it to ride like a caddy. Thanks
Posted via Mobile Device |
11-22-2012, 11:33 PM | #2 |
Re: How well can it ride and steer? Cpp
Id personally be looking into Porterbuilt stuff for that kind of money. Seems like a lot more money than you really "need" to spend tho.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
11-23-2012, 12:13 AM | #3 |
I used CPP on my truck, and it really rides great! Also new A-arm bushings, upper lower ball joints, sway and track bar! Really pleased with it!
Justin |
11-23-2012, 01:43 AM | #4 |
That kind of money? The majority of the money is for a complete $1600 brake kit. My truck has drums front and rear so its the best route for me. The total suspension may be around $800, Thats nowhere near the cost of porterbuilts products.I dont need air ride because of the cost and im more of a hot rod guy. I really like the autocross trucks by no limit. I just need my truck to ride like a new vehicle because when im finished, itll be my daily. Thanks guys
11-24-2012, 01:32 AM | #5 |
I did a 5/7 drop from cpp with front and rear sway bars and cpps shocks and its ride smooth and handles well i love it and never would second guess it
11-24-2012, 02:19 AM | #6 |
Old member
When you get done with the new components it will ride like a new truck!
It may not be the right year truck though!
11-26-2012, 01:10 AM | #7 |
I am also planning on using CPP to replace a ton of parts on my 67, the more opinions on there brake/drop/suspension parts the better,Thanks!
11-26-2012, 06:31 AM | #8 | |
What type of ride are you really looking for? Corvette? Carve some corners? Not too stiff, not soft and sloppy like a cadi? A rebuild with new bushings, new coils, new rear leafs w/new bushings will make your truck ride like it did from the factory. Add some adjustable shocks and get it more tuned to the way you might like it. Personally I like to be able to swerve around an object at 45 mph and not fishtail, rear end come out or other wards slide off the road and crash. That’s not a cadi or a corvette ride, that’s “safe”. |
11-26-2012, 09:36 PM | #9 |
the boat guy
You can really do a lot with a good agressive alignment, good shocks, and drop spindles.
Even if you spend a ton of money on a racecar chassis if you don't know how to set it up its not going to perform. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
11-26-2012, 09:59 PM | #10 |
Fabricate till you "puke"
2nd that! My old truck has been out past 140....its a spooky ride after about 130? Backyard Buck style(cut coils /front, with shock relocators), flipped rear, ...less about 4 leafs on the stack/ slapper bars. The complete mess is budget , to the Hillbilly Bone.....she brings this crazy old man back, evry time out crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-26-2012, 10:04 PM | #11 |
I just completed a 67 doing exactly what your speeking of and had less than $2200 in all of it. i shopped at 3 different places but saved a ton of money and even installed new brake lines
11-27-2012, 11:19 AM | #12 |
Name those places please lol
11-27-2012, 12:56 PM | #13 |
It's all about compromise. Real good ride will make it mushy around corners. Real good around corners will make it ride rough. You can however make it ride pretty good and corner better than the truck that it is. My truck rides and corners better than my buddy's Chevelle but that's not a Caddy.
11-27-2012, 01:09 PM | #14 |
In my opinion, if you want it to ride like a caddy, buy a caddy.
Its a truck! You can always improve general components that are older and probably need replacing anyways to improve it .. but its a truck! let it ride like one
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
11-27-2012, 01:15 PM | #15 |
look at no limits rack and pinion. probably for the price of all the steering components you will be close to the same price. R&p is sooo much nicer
11-27-2012, 09:16 PM | #16 |
