11-23-2012, 12:14 AM | #1 |
Using Stock Springs in 60 - 66
I'm wondering with newer axles swapped in what differences with day to day use would a person notice?
I'm curious to get input from people using stock springs for day to day use vs. updating to newer springs & hangers from a 73 & up. |
11-23-2012, 02:20 AM | #2 |
Re: Using Stock Springs in 60 - 66
The only difference that a "later model" spring would make is that later model trucks use longer leaf springs. The difference in leaf lengths changes the handling characteristics.
Now if you just mean a "new" leaf, as in a replacement, then new leaves can be purchased with different spring rates, and other features, for a given length. If replacing old, worn out springs then it should certainly be an improvement. I don't think the axles will affect the ride much, other than a change in unsprung weight when going from 1/2 ton axles to 1 ton axles. How do you intend to use your truck? You really have to decide on what your truck will be used for before you can make a decision on things like suspension setup. My dad has a similar pickup and drives it around town daily. It works just fine for him.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
11-23-2012, 11:20 AM | #3 |
I'm more of less going to build the truck for pleasure / light work. The 4wd I picked up looks like it has decent springs / hangers on it.
I am not going to run the older axles, so at this point it looks like I will update the drive train & leave the springs. The blocks don't bother me. Appreciate the reply. |
11-24-2012, 01:09 PM | #4 |
"If it ain't broke, don't fix it!"
