Old 11-23-2012, 12:15 AM   #1
Mbooher
1972 Big Block SWB ... Driveshaft Question... Need a little help...
I am building a 1972 SWB Big Block truck with a Turbo 400 Transmission & I have an Original Big Block Cab for it.... The frame is from a 1972 SWB Small Block, Automatic Transmission truck......
My question is this.... Did the 1972 Short Bed Big Block Trucks have two piece drive shafts or a One piece?
My Frame I am using has the carrier bearing bracket to support the carrier bearing of a two piece driveshaft.... Which I was thinking of removing the bracket.... Unless the BB Short bed trucks had two piece driveshafts as well & I will go that route....
I have another 69-70 Short bed frame that does NOT have the carrier bearing bracket but that frame was an original Small Block, standard shift truck.... therefore... I am curious how they were from the factory when there was a Big Block in them....
I am only interested in the Short Bed configurations.....
Any help would be appreciated....
Mark Booher
BooherPerformance@earthlink.net
Mbooher is offline   Reply With Quote
