Old 11-23-2012, 12:43 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Pinion angle shims, bumpstops
Here is a set of 5 degree pinion angle shims for lowered trucks. They will also lower your truck an additional 1/2 inch. Included is a set of bumpstops that can be used inside of a c-notch, or bottom of the frame rail if not running a c-notch. $40 Shipped in the USA for all.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-25-2012, 10:51 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Pinion angle shims, bumpstops
Bump.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-25-2012, 11:23 PM   #3
budnikguy
budnikguy's Avatar
Hey man, how much picked up?!
budnikguy is offline   Reply With Quote
Old 11-25-2012, 11:27 PM   #4
HotRod C/10
HotRod C/10's Avatar
Are these for coil spring trucks?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-26-2012, 12:30 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Adam- ill do $30 picked up.
They will work for both I believe. I had them on a coil sprung truck, but I think they will work for a leaf sprung truck, as the hole in the center would allow it to be centered on the pin used in leaf springs.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-26-2012, 01:18 AM   #6
budnikguy
budnikguy's Avatar
COOL, pm me your # and I will make time to stop by!
