1972 Big Block SWB ... Driveshaft Question... Need a little help...
-------------------------------------------------------------------------------- I am building a 1972 SWB Big Block truck with a Turbo 400 Transmission & I have an Original Big Block Cab for it.... The frame is from a 1972 SWB Small Block, Automatic Transmission truck...... My question is this.... Did the 1972 Short Bed Big Block Trucks have two piece drive shafts or a One piece? My Frame I am using has the carrier bearing bracket to support the carrier bearing of a two piece driveshaft.... Which I was thinking of removing the bracket.... Unless the BB Short bed trucks had two piece driveshafts as well & I will go that route.... I have another 69-70 Short bed frame that does NOT have the carrier bearing bracket but that frame was an original Small Block, standard shift truck.... therefore... I am curious how they were from the factory when there was a Big Block in them.... I am only interested in the Short Bed configurations..... Any help would be appreciated.... Mark Booher BooherPerformance@earthlink.net |
![]() Join Date: Jan 2002
Re: 1972 Big Block SWB ... Driveshaft Question... Need a little help...
I am 99% sure it would of originally had a two piece. However i am not a fan or carrier bearings and i always convert to one piece driveshafts. Any good machine shop can cut a driveshaft thats too long and balance it(and switch out yokes if need be).
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#3 | |
the boat guy
I think 6 cyl manual trans swbs came with a one piece driveline. I have built many one piece driveshafts for lowered swb and lwb trucks with no problems. 2 piece drivelines do serve a purpose, they can rotate at higher speeds per a given lenth, and can be used to accomidate some strange driveline angles. If you're just building a street truck with less than 700hp that won't go over 140 mph a one piece 1310 shaft will be just fine. Don't use precision or house brand ujoints. Get some nice non greaseable spicer or neapco joints Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Grandpa in the rustmobile...
My shortbed 69 70 truck has a th400 and its a 2 pc driveshaft
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
OK Guys...
I build all types of Performance cars & trucks......Thanks for the tips but..... My question is..... What came from GM in 71-72 when the Truck was a Factory Big Block \ TH400 & had a Short bed? One Piece or Two Piece? The truck will be an Original restoration type build..... It will have a BB & a Turbo 400 Transmission.....Light cam at best.... I assume these came from GM in one configuration..... just thought someone has an Original 1971-72 Big Block Short Bed or has torn down & or Built several of these over the years & can confirm the type of driveshaft used.... I do know I can make it work either way but I would like to find someone that has an original 71-72 BB truck that could tell me the answer.... Anyone have an Un-Molested Original they can look at? |
Loves all GMC trucks
![]() Join Date: Jul 2010
I have a BB SWB truck but it is not factory.
I searched and found an old post from Special K in 2006! http://67-72chevytrucks.com/vboard/s...d.php?t=207962 Well respected on this board... If he said it, pretty sure he knew the answer. The old driveline shop here in Wichita charged me about $140 to cut, spin balance and add the correct yoke and spicer u joints. Reasonable price for all that work. They mentioned that it's short enough for a 1 piece unit but it's only like 10 inches from their length threshold. They mentioned that the support allows for better ride quality under load (flexing I guess). Sorry for the book... Hope it helped. Mike Posted via Mobile Device |
Should be a 2 piece. Remember , there are atleast 3 different carrier bearings and brackets. If your frame was a small block it probably has a small block carrier bearing bracket rivitted to the frame. A big block bracket is bolted to the frame.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Originally for a big block auto, 2 piece driveshaft.
and bradman, some of us arent fortunate enough to have driveline shops close. My local machine shop does an excellent job on driveshafts, I've had a few done there and no issues to date.
#10 | |
the boat guy
![]() We stopped building them shafts when they started wanting us to pay them to build them a shaft. You wouldn't believe how many professional mechanics don't know how to install a ujoint, seems pretty simple, and it is but people still manage to ruin ujoints and driveshafts. Posted via Mobile Device
Can anyone tell me if a 53" one piece driveshaft out of a 67 GMC will work in in an 86 SWB with small block and Turbo 400?
#12 | |
the boat guy
The 67 gmc should have a 1310 rear ujoint. Posted via Mobile Device
#13 |
sameyrasmea72
Thanks for the information & the photos.... I think you answered my question & taught me something... I didn't know about the Bolt in vs the riveted carrier bearing brackets... I have an original unmolested 72 Longbed BB Chevy I am going to look at just to see what it has... It is a Leaf Spring truck though.... that might make a difference... My SWB was a Small Block truck for sure.... but I am converting it to a BB since it is from the frame up on the restoration... |
#14 |
