Old 11-23-2012, 12:17 PM   #1
JVC
Disc Brake Conversion
Hi, does anyone have any information on using Chevelle type disc rotors as a conversion? I have a 1968 C10 with a 454 and drums all the way around. Looking at changing out the front, again just seeing if anyone has tried it or not. Thanks
JVC is offline   Reply With Quote
Old 11-23-2012, 12:45 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc Brake Conversion
Chevelle rotors will require you to run a chevy "car pattern" wheel.
(5x4.75)
I personally would buy a set of 63-70 conversion spindles, and keep the 5x5 pattern or even the original 6-lug pattern.
Keith
Convert to disc brakes.
Old 11-23-2012, 12:54 PM   #3
lolife99
lolife99's Avatar
Here's what you asked for.
http://www.classicperform.com/Instru...BK-6370DBK.pdf
I see no money savings with this set up other than not having to remove your original drum brake spindle.
Keith
Old 11-23-2012, 01:18 PM   #4
BarryB
BarryB's Avatar
After reading that, makes me wonder why couldn't you use rotors from a caprice or cadillac. Any GM fullsize car with the big 5 on 5 lug pattern.
One benefit using the smaller lug pattern. 4.75 is the availability of wheels. Here it seems there are always plenty of used wheels to chose from on Craigslist. If your on a tight budget.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 11-23-2012, 02:08 PM   #5
JVC
Thanks for the info. Just looking at every option.
