C/10 junkie
Brand new 71-72 front brake hoses
Brand new set of front brake hoses with copper washers for 71-72 2wd. Asking $30 shipped for the pair.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
C/10 junkie
Re: Brand new 71-72 front brake hoses
Pics
![]() Posted via Mobile Device
The Waco Kid
I'll take em! Please send payment info! Greg
C/10 junkie
67-72 parts collector,…
![]() Join Date: Nov 2002
shawno,... why aren't you using these?
I saw your other thread wanting conversion hoses, so I am confused.
C/10 junkie
Well after reading your info page I thought thats what I needed. I plan on keeping the original 68 brake lines and didn't want to run adapters. Am I wrong?
#7 | |
Since you already own the 71-72 hoses I would use those. (they will be slightly longer since they don't have to reach all the way to the front of the crossmember to connect to the steel line) Have you looked to see if you can bolt these directly up? Inverted flare adapters will cure that and are around $5 each here locally. I understand wanting to plan out your build before you start,... but it just might pay to look under your truck and check. Didn't mean to upset your for sale thread.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-23-2012 at 07:48 PM. |
Conversion hoses from ECE part #03-6480 are $55.00
71-72 hosed locally to me are listed as left and right. (meaning the steel line connection is a different size on one side) RH is $24.00 LH is $23.00. But one will require an adapter.
C/10 junkie
All is well Keith, I did my homework and like you said the left and right side have different size holes. I just figured that I might as well go with the conversion hose for a cleaner look. I found a set on the POL website for $35.99 so I think I will go with those.
http://www.performanceonline.com/FRO...FBHK-R-FBHK-R/
#10 | |
![]() Join Date: Aug 2011
Thanks Joe Hester |
![]() Join Date: Aug 2008
I will take these if lybnfield passes
Posted via Mobile Device |
#12 | ||
C/10 junkie
![]() Quote:
#13 |
[QUOTE=shawno72;5722464]Yes these can be adapted to work or you can choose to buy a set of the "conversion" hoses like I did and they will bolt right up, so to speak
![]() Thanks for the info buddy ![]()
Thanks Joe Hester |
#14 |
C/10 junkie
Your welcome Joe.
