Old 11-23-2012, 04:14 PM   #1
barrykathy
electronic choke conversion
is there a electronic choke conversion kit for a 1971 in line 6 . i have seen some for V8 not any for a 6 or what is the best way to fix the choke ??
barrykathy is offline   Reply With Quote
Old 11-23-2012, 04:18 PM   #2
trac209
Re: electronic choke conversion
Well what exactly is wrong with yours? is it not working at all or missing? I would probably hook up a manual choke if your choke spring assembly is missing or no good. And it gives you the best cold weather starting control as you can adjust on the fly.
trac209 is offline   Reply With Quote
Old 11-23-2012, 05:55 PM   #3
Bullittben
I have a 70 with a worn out spring on the choke. I hooked up a manual choke, but the aftermarket ones are very poor quality now. Wish I could find a good one. I'd really rather have a new spring, but that seems to be hard to come by....wonder if the V8 one would work?
Bullittben is offline   Reply With Quote
Old 11-23-2012, 06:15 PM   #4
barrykathy
the LMC catalog shows one for the 6 but the picture does not look any thing like the spring on the truck now
Old 11-23-2012, 06:32 PM   #5
trac209
A manual choke has no spring,it's connected to the choke linkage itself and adjusted from the cab via the cable
Old 11-23-2012, 07:22 PM   #6
ghostvbhc
ghostvbhc's Avatar
The choke cable I had in my 69 c10 with an inline six wouldn't reach so I went to o'reillys and bought their manual choke conversion kit for about $20 and it works great. I would suggest it.
1969 Chevy C10 250 straight six. Still a work in progress.
ghostvbhc is offline   Reply With Quote
Old 11-26-2012, 02:21 PM   #7
Bullittben
Trac we were talking about replacing the original automatic choke spring. Larry, the only thing I see in LMC is a choke pull off. Not a choke thermostat.
