Rally wheel painting.
So in the 1st pick you can see that my rallies are in bad shape, that ones a good one. My materials are in the 2nd pic, plus sand paper. I sanded wheel down till completley smooth ,using 220 grit, then applied 1st coat of primer. Between 1st and 2nd coat of primer I wet sanded using 400 grit. 3rd pic is after 2nd primer coat. I did three topcoats follwed by three clear coats. 4th pic is 3rd topcoat before clear. 5th pic is the finished product. Im doing these one at a time because I need to drive my truck. When Im completley finished Im going to get 3in. trim rings, take the center cap paint off, and get some gmc inserts for the caps.
1979 ![]() 1996 Silverado x-cab "the daily" |
Re: Rally wheel painting.
Nice!
I just took mine to get powder coated Let me know where you can find those GMC inserts... I cant find any |
#3 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Thanks guys! Can't wait to get the rings then it will look real smooth.
@ramz classic industries is the only place I've seen the inserts at, there 20 bucks a piece though. Posted via Mobile Device
got a part number? I only find the chevy bow tie emblem Last edited by ramz; 11-23-2012 at 07:48 PM. |
Sure do, #469667
20 Bucks is a bit steep... When they sell the chevy one for 5 bucks... lol Maybe someone else knows we can get these??? |
Those look great. Did you have them sandblasted?
You might check with PT'S 70 CST for the center cap emblems. Has for Chevy, not sure about GMC.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#9 | |
Is he a member here? Posted via Mobile Device
I just did the same to my rallies last summer, got them sandblasted and epoxy primered, then paint and clearcoat, and bought new 3" rings from lmc.. they are the only wheels for square! Looks great!
1987 Chevrolet Scottsdale R10 Diesel "gasoline is for washing your paint brush" |
#11 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=512551
Ill have to check into that. Ebay and amazon don't really have anything good; it seems that everything GMC is expensive..
#13 |
Just back from powder coating
![]() Last edited by ramz; 12-03-2012 at 10:42 PM. |
#14 |
*removed.
#15 |
I did score this GMC insert...3 more to go
http://cgi.ebay.com/ws/eBayISAPI.dll...m=281022659904 |
#16 |
Always a work in progress
The centers can polish up real nice with some elbow grease and time. I did it to mine and they came out real nice.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#17 |
looks good
#18 |
I'm going to do this sometime in the near future but, I'll be making my rims black. Thanks for the tips.
#19 |
Thanks now I just need to get them finished lol!
That powdercoat looks good ramz. Searching for those cap inserts is a nightmare. @99-ls1, I sanded mine cause it didn't cost me money, but having them sandblasted would make it alot quicker.
1979 ![]() 1996 Silverado x-cab "the daily" Last edited by GM-power; 12-07-2012 at 09:50 PM. |
#20 | |
#21 |
I know you did multiple coats of everything but where they thick coats or light coats? I have 5 rallies in the back of my truck waiting for paint and I've got a coat of primer on one. Just trying to figure out best way to go about this. Does the primer really need to be sanded with fine sandpaper before paint? Thanks.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
#22 | |
I forgot to mention the paint color I used, it duplicolor metallic silver #1679
#23 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If you know anyone with a soda blaster, it takes the paint off as fast as you can spray it. I did a set last summer. Total time to strip all four center caps to shiny chrome was about 2 minutes.
#24 |
When I got my caps I tryed a razor blade and cleaned the paint of mine with that and finished with some rubbing compound. Then some buffing glaze on a rag to finish them they cleand up great. need cleaning and waxing again now also. that was about 3 years ago
#25 |
Found a set of caps with inserts on ebay. Some pitting, but for 17 bucks I couldn't pass it up.
