11-23-2012, 10:22 PM | #1 |
Help with speedometer cable?
I ordered a brand new speedometer cable and when I hooked it up, it didn't work. Now, I checked to see if everything was hooked up and tight and where the cable hooks up to the transmission, it feels as if it isn't hooking in all the way into the transmission and the speedometer isn't reading anything at all. And, I feel as if when I shift it into gear the speedometer cable is gonna end up getting chewed up because it looks like the cable isn't fitting right and it's hitting the bottom of the shifter. I have a three speed manual transmission in the floor. If anybody could help me with this, I'd appreciate it.
1969 Chevy C10 250 straight six. Still a work in progress. |
11-23-2012, 11:17 PM | #2 |
The Older Generation
Re: Help with speedometer cable?
Are you sure the plastic trans speedometer gear is in place? Edit: Actually there are two, one on the trans output shaft and one in the cable adapter. If you check the first picture at this web site you can see the two gears. (this is a 700 r4 trans) http://www.transmissioncenter.net/sp...n_______va.htm LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-23-2012 at 11:25 PM. |
11-24-2012, 12:18 AM | #3 |
Also you can hook a drill up to the cable to make sure the speedo itself is working, if thats working then you know the gear in the tranny is not spinning the cable.
Posted via Mobile Device |
11-24-2012, 03:25 PM | #4 |
I'm gonna do the drill thing with the cable and see if it's working. I just don't wanna drive around without a speedometer haha.
11-25-2012, 12:20 AM | #5 |
So, I did the thing with the drill and speedometer cable works, so we can't figure out why it isn't working. Maybe it's just not hooking up to the transmission all the way.
11-25-2012, 03:21 AM | #6 |
Old member
When you look at the transmission where the cable goes can you see any plastic. The plastic gear may have striped out on the end where the cable goes into it.
This is what the gear looks like if you take the tail housing off the trans.
11-25-2012, 11:31 AM | #7 | |
Active Member
I have found the biggest problem is the actual engaging of the squared off ends. Sometimes the upper end is cross threaded into the dash and even though if feels tight, won't engage completely. Also the end on the transmission does not engaging the driven gear properly. To check the complete cable, take the bullet out completely from the transmission and with the cable connected at both ends twirl the driven gear quickly. The needle should jump. If all above tests are okay, check the teeth of the internal drive gear and make sure it's not loose.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-25-2012, 02:15 PM | #8 |
The speedometer needle moves when we did check it with the drill.
11-26-2012, 11:23 PM | #9 |
I found my problem, we lost that gear in the transmission some how.
11-26-2012, 11:27 PM | #10 |
Hybrid67
had the same problem and had to dig one out at the junkyard
Keep em' Running! All show.....no go |
11-26-2012, 11:32 PM | #11 |
Hybrid67
classic parts also has a selection of them for certain setups for anywhere from $6.50-$11.00. Usually in certain colors depending on the tranny /gear ratio/tire size etc.
11-26-2012, 11:32 PM | #12 |
We might have to do that. Or, does anybody know where I can order one from? I was gonna try o'reillys tomorrow after work.
Edit - ^ Nevermind, I'll just order one from there haha. Double edit - Can anyone help me to determine which one I should order? I have a three speed manual in the floor.
11-27-2012, 12:02 AM | #13 |
Hybrid67
not sure on that one. Hopefully someone else chimes in on the tooth count of the original based on your specs. Do you know your rear end ratio so it can be more easily determined for another subscriber? If not, I found a thread on the site a few years back searching for the same info and seem to remember getting some info from it based on what I knew of my own setup.
Good luck and I hope you find what you need.
11-27-2012, 12:04 AM | #14 |
Ill have to get that information tomorrow and hopefully someone can help me out. Thanks though man.
11-27-2012, 05:08 AM | #15 |
should b able to get that part local autoparts store or GM parts counter
buy local and you dont have to wait or pay shipping
11-27-2012, 05:12 AM | #16 |
Old member
I hit the local transmission shop and got a free one out of another transmission. They have hundreds of them laying around.
Well my local shop did anyway.
