11-24-2012, 03:46 PM | #1 |
Chevy Only Tx
Narrowed Porterbuilt Arms-Now Bags Rub-HELP!!
I bought some Porterbuilt narrowed arms, started assembly now bags are rubbing my spindles. Also the nuts on the top arm only have a couple rounds on them and I don't think even if I shimmed them to where the nut is now that it would make a difference. The bags are Dominator 2600s would Slam Specialties get me out of this bind?????
Chevy Only Tx......... |
11-24-2012, 04:52 PM | #2 |
Re: Narrowed Porterbuilt Arms-Now Bags Rub-HELP!!
How does it fit when fully assembled? How much were the arms narrowed?
My arms have been narrowed 1", the bags are slam specialties and the drop spindles are McGaughy's 2-1/2". As you can see there are no rubbing issues.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
11-24-2012, 05:31 PM | #3 |
What source of information are you basing your statement on? I bought both my arms as well as my dropmember directly from Nate, so i'll have to disagree with that statement.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 11-24-2012 at 09:20 PM. |
11-24-2012, 05:39 PM | #4 |
67-72 parts collector,…
You are not suppose to run the "Forward Series" arms with the Dropmember.
The narrowed arms are fine. As for the OP's question,... bolt your lower a-arm to the bag and install the shock. Then tell me if you have any interference. You will never get that much lift to make the upper part of the spindle come into contact with the bag.
11-24-2012, 06:14 PM | #5 |
Chevy Only Tx
They were narrowed 1"
11-24-2012, 06:15 PM | #6 |
Chevy Only Tx
But then again I'm running the older V3 dropmember & CPP drop spindles.(not modular)
11-24-2012, 06:26 PM | #7 |
Have you fully assembled the suspension yet? If so do you have any pics? I am running an early DM as well.
11-24-2012, 06:55 PM | #8 |
Chevy Only Tx
Not yet. Came to test out the new Ar15 & 12 gauge. I will get back at it here tonight or early in the morning tomorrow
11-24-2012, 11:08 PM | #9 |
I think it would be fine once you fully bolt in the bag it will sit a lot lower then that.
11-25-2012, 12:50 AM | #10 |
Chevy Only Tx
Thanks for all the input guys. I will work on it in the AM. Lolife99 I currently don't have shocks yet so I will just cross my fingers that when I bolt the bag on bottom that it will work. If all goes well before I mount the body I can buy some
SS bags still. Thats what Nate recommends if I recall correctly. Posted via Mobile Device
11-25-2012, 12:55 AM | #11 | |
Don't let it hang by the bag. The shocks are the limiting factor to prevent damage to the air bag.
11-25-2012, 01:02 AM | #12 |
yep, put it together, you wont have a problem. in that pic you'll never be that "high" unless you run hydraulics instead of bags
11-25-2012, 03:14 PM | #13 |
Chevy Only Tx
Whew!... Man I was stressing for nothing. Thanks guys!!!
I was like " man I finally get on a good start and then THIS?"... Sigh of Relief...... Posted via Mobile Device
11-25-2012, 03:17 PM | #14 |
We all have those days. Glad it all worked out for ya.
11-26-2012, 11:07 AM | #15 |
I wish I would have seen this over the weekend.... could have put you at ease with a few words! LOL
Glad you got it all put together, and it's looking good! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
11-26-2012, 11:20 AM | #16 |
Chevy Only Tx
Thanks Nate!.... Man I was stressing BAD!! But with help from other members I got through it.
