Old 11-24-2012, 05:20 PM   #1
84 400
Sb 400 club
84 400's Avatar
1/2 ton to 3/4 ton backing plate??
The conflicting info on this is crazy!!
I have searched disc diameter and the 1/2 ton is roughly 11 3/4 and the 3/4 is 12 1/2. Do any of the half ton backing plates work for the 3/4 ton swap?? Some say no some say yes. The calipers are the same p/n.
Peterson's did an article and said you can reuse the backing plates. I will link it below. My 77 has mint backing plates I would like to reuse if possible.
Any input would help
Link to one article claiming you can reuse the 1/2 stuff
http://www.4wheeloffroad.com/howto/3084/photo_08.html
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-24-2012, 05:42 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 1/2 ton to 3/4 ton backing plate??
If you are talking about the front brake backing plates on D44’s or Corp 10 bolts, yes….you must replace the backing plates to the larger ¾ ton type as they are larger in diameter. The 6 lug ½ rotor is 11.86 in diameter while the 8 lug ¾ ton rotor is 12.5. You’re probably thinking of brake calipers as those you do not need to change. Both ½ ton & ¾ ton use the same calipers
This wouldn't be the first time the 4x4 rags have been wrong.
DirtyLarry is offline   Reply With Quote
Old 11-24-2012, 07:58 PM   #3
84 400
Sb 400 club
84 400's Avatar
Thanks. Love your rig btw.
after reading the size charts I thought there was no way it could work.
Does anyone know the GM part number?? Apparently you can still buy them new....
1985 C10 LWB Sold
Old 11-24-2012, 09:14 PM   #4
obijuan
supposedly 3/4 ton calipers are different piston something or other this and that. dimensionally identical to each other.
i have seen half ton pads in a 3/4 ton caliper and 8 lug rotor did not fit. wider pads so they wouldnt slip over the 8 lug rotor. can not confirm if that was a manufacturer design difference or what. hearsay i suppose.
obijuan is offline   Reply With Quote
Old 11-24-2012, 09:58 PM   #5
DirtyLarry
DirtyLarry's Avatar
I don’t believe the backing plates are available anymore. Heck, I couldn’t even find them on the AC Delco, Napa Prolink or Dorman’s website
Hearsay or something because the calipers and pads are the exact same part number between on the ½ ton and ¾ ton. The backing plate is different because it moves the caliper outwards a tad in order for the pads to line up with the larger diameter ¾ ton rotor.
Old 11-24-2012, 11:16 PM   #6
eric67m
eric67m's Avatar
Not to sidetrack but...
If both 1/2 T and 3/4T calipers are the same on dana 44's....
When doing a 14 bolt rear disk swap must I use all 3/4T? It sounds like on the rotors I would use 3/4 T to match the front. But the calipers for the rear could be dana 1/2 or 3/4 ton. Could I also use 10 bolt calipers?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-25-2012, 01:08 AM   #7
84 400
Sb 400 club
84 400's Avatar
Yes you can use 10 bolt calipers or Dana or 78 cadilac elderado calipers for the ebrake function. Who's brackets are you using? I am using diy4x.
1985 C10 LWB Sold
Old 11-25-2012, 09:14 AM   #8
eric67m
eric67m's Avatar
I have a set of ruff stuff specialties brackets. I have not put them on yet. I held a set of 10 bolt calipers up to them and they seemed to not line up. I will have to take another look. Only looking for dana 44 8 lug calipers limits my junk yard search immensely.
http://www.ruffstuffspecialties.com/...ry_Code=BoltOn
Old 11-25-2012, 11:15 AM   #9
84 400
Sb 400 club
84 400's Avatar
I just get my 10 bolt calipers at Napa. They are less then 20 bucks a piece. As DirtyLarry mentioned the 10 bolt uses the same part number for calipers weather 3/4 or 1/2 ton. On there site it says u can use 73-87 3/4 ton calipers. After 77 gm used the 10 bolt so the calipers should fit. Also a guy in the reviews is using elderado calipers which are the same dimensional as the 10 bolts.
1985 C10 LWB Sold
Old 11-25-2012, 11:51 AM   #10
LONGHAIR
Yeah, I wouldn't bother with junkyarding for brake calipers either. You still have to deal with things like rusted or plugged bleeders, boot tears, leaks, etc. Buy some from a local parts place.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
