Old 11-24-2012, 05:37 PM   #1
jbgroby
jbgroby's Avatar
Yeah - FIRE is GOOD
Nuttin' like fire to move a stubborn part. The OEM rubber bushings in the sway bar were stuck beyond reasonable effort. I could have spent 15-30 minutes drilling and pushing the bushings out, BUT mans friend is FIRE. Light’em up with a torch and let them burn for 2-3 minutes and the old ones drop right out!
I let the bar cool, cleaned the ends and drove the new one in with an old ¾” socket. Worked like a charm. This bar and these bushings have been sitting on the bench for over a year at least. Glad to get them out of the way.
P.S. Burning Rubber do be stinking though!
jbgroby is offline   Reply With Quote
Old 11-25-2012, 02:00 AM   #2
Captainfab
60-66 Nut
Re: Yeah - FIRE is GOOD
Yep, burning them is the easiest way to remove rubber bushings. Once they burn for a little and the rubber starts to ooze out, you can typically knock the center out. Definitely a job to be done outside though
Old 11-25-2012, 10:53 AM   #3
duallyjams
duallyjams's Avatar
What no marshmallows
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-25-2012, 02:20 PM   #4
jbgroby
jbgroby's Avatar
Nope you can't tell the crispsy marshmellow from the burnt rubber ;
