What's this lower trim piece?
Here's a pic of my '69. It has the holes for the silver trim pieces near the top of the tailgate. I also have the trim around the two tail lights. Anyway, I'm looking to buy the kit that includes all the pieces, but I'm seeing an additional lower piece that it includes in the kit, but I don't see mounting holes for it on my truck. Did my truck originally come with that piece or not? How does that lower piece install? Adhesive?
![]() ![]() Posted via Mobile Device |
Re: What's this lower trim piece?
Pretty sure your truck should have both the upper and lower trim strips with the Z62. Here are two pictures for you. In looking through a number of pictures I am wondering if your tailgate is original to the truck. It seems to have flaking to a dark undercoat. Has it been repainted? If so that could explain the difference. If not just go ahead and install it if you want it. Might take a loook at a '69 or 70 brochure before deciding and see how Mar-K is listing the tailgate trim set at their site.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#3 | |
Old member
Mine had clips on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Actually LMC seems to do a good job here showing the type location and quantity required in the so little picture. Thought maybe a little color and a resze might help. Kit callout 11 should cover the tailgate and 12 for everything else.
#6 | |
![]() Join Date: May 2010
My 69 CST never had the lower tailgate trim. I can't imagine the CST would not have had it if it were available unless it was part of the upper molding option which Tim's pictures indicate is not the case. I saw a previous thread here in the last year that suggsted it was a Blazer thing. Perhaps it was added to the later model years?
#8 | |
Customs in 67-70 got the lower tailgate trim,as did base trucks with the lower trim option. Also,67/68 CSTs were trimmed the same way. Starting in '69 the CSTs got a tailgate band and no lower trim on tailgate. Same in 71/72 only Customs became Custom Deluxe and CSTs became Cheyennes. There are holes in the lower gate to accept the trim mounting clips
Here's a picture of the rearend. Never painted/touched. Only thing changed is the aftermarket sport bumper.
#11 | |
my 72 , came with the chrome across the bottom . but was held on with clips and has the holes in the gate for the clips. ..
#13 | ||
Roadtrip!
![]() Join Date: Feb 2003
I think tim has it here. The only way i have seen all 3 pieces is on a CST blazer. mister b, i think yours would have the upper and lower trim. (the thin ones)
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#14 | |
#15 |
2WD Jimmy
![]() Join Date: Mar 2005
[QUOTE=
I think tim has it here. The only way i have seen all 3 pieces is on a CST blazer. mister b, i think yours would have the upper and lower trim. (the thin ones)[/QUOTE] Yea, my 72 Cheyanne package Jimmy has all 3 pieces. Posted via Mobile Device |
#16 |
Yep,Fleetside trucks came three ways from 69/70,as far as rear trim goes:
* No trim-C/10-30 * Tail lamp trim,on tailgate across the handle and cross the bottom-Custom/10-30 * Tail lamp trim,on tailgate across the handle and woodgrain band in center-CST/10-30
#17 |
Good info here. Makes sense too!
#18 | |
#19 | |
On the path to financial ruin!
![]() Join Date: Jan 2009
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
#20 | |
#21 |
Looks like you all have confirmed my original thoughts on this. It should have both the upper and lower tailgate trim at the Custom trim level. Why this truck does not is anybody's guess. Still think the gate may have been changed and repainted by the paint flake patterns.
Dug up in my Longhorn files a very original Custom Camper C/20 Custom and a similar CST for some as built pictures.
#22 |
Old member
The picture of the rear of mine in the picture was never touched as far as I know. I was the second owner of the truck. It was a Custom Deluxe and had the bottom trim with holes (no Glue) and clips. I had all the trim removed last time I painted it and welded up.
I would say the tailgate was swaped at some point in the trucks life. Newer tailgates have the holes I wonder. Would be a lot easier for them not to and just make you drill them depending on what trim level of truck u are going for. ![]() ![]()
#23 | |
#24 |
You're welcome
#25 |
