Old 06-03-2003, 10:21 PM   #1
Wreck
Find anything cool in your truck
what have you found in your truck when you bought it..I found this little treasure behind the seat next to the gas tank.
Wreck is offline   Reply With Quote
Old 06-03-2003, 10:38 PM   #2
dinnut
dinnut's Avatar
i found 2 ignition locks without keys, 2 bottles of tranny fluid, a master cylinder and bunch of other crap....
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 06-03-2003, 10:45 PM   #3
Class of 69
Class of 69's Avatar
Talk to Joesjunk. He's still trying to cash the travelers checks he found
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 06-03-2003, 11:19 PM   #4
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
a homemade knife about 8in mabe out of 1/8 flat steel 2in wide double bladed
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 06-03-2003, 11:19 PM   #5
Warbones
Navel Inspector
Warbones's Avatar
Nothing inside yet!
I did find a piece of metal in the glovebox. Looks like a bracket of some sort. Not sure what it goes to. Might be battery. In the bed I found Dirt, leaves, wood ( from the bed ) wood covering the wholes from the missing wood in the bed. A couple of pop cans and an old fuel filter.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 06-03-2003, 11:31 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
knife
I found a fish filliting knife down in the pocket in the front fender. still sharp but rusty...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 06-03-2003, 11:40 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The military police found a dime bag in the drivers side cab corner once...hence the previouse owner's nick name.
I think he smoked every time he worked on it. If you were to work on it you would understand why I suspect this.
Old 06-04-2003, 12:00 AM   #8
ol skool 68
turnin wrenches
ol skool 68's Avatar
after cutting through alll the bondo on the cab corner, i found the previous owner was a busch lite drinker........he had cut the top and bottom off the can and slit it down the side in order to get it to help hold the bondo he was putting in.........now i can almost fit both fists through the hole lol.........oh i found some wrenches behind the battery and a safety belt held together by clothes pins............yeah that would have worked lol
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 06-04-2003, 12:08 AM   #9
SEVEND2
SEVEND2's Avatar
since the truck was my parents truck before me....hmm about 89 cents under the floor padding, a pencil, about 1/2 gone, and my dads machette (the long azz knife) where the jack on the right side was suppost to be.. I asked my dad and he said i dont need a jack, the tire iron was to small, so he put the knife in there ((hmm i was kinda speachless after that, for a bit))
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 06-04-2003, 12:12 AM   #10
1969 GMC
1969 GMC's Avatar
so far i've found a ton of crap. a maybe 12" long piece of 8x8 lumber was in the front fender pocket (under where aux battery would go), and a piece of wood trim complete with nails in it, along with a lead pipe and a container of after bite (makes bug bite itch go away). Inside, I found the little build tag that goes on the seat, a glass jar of bar's leaks, an old pull top can of prestone antifreeze, a can of 10w30, a glass jar with 3 fuel filters in it, a 1973 map of minnesota, and a sticker from the LeSeur county fair (in minnesota), and a strange piece of wire that has a loop on one end (like you'd stick your finger in it) and the other end is hooked. There was also about 30 feet of spare 18 ga. wire wrapped around the tranny shifter, and about 30 more feet masking taped to the back of the dash.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-04-2003, 12:21 AM   #11
Longhorn Man
That sounds liek the old peel off tops on a pop/beer can! (how old are you?)
Old 06-04-2003, 01:04 AM   #12
72shadetree
KEEP ON TRUCKING
a buddy of mine ran a bodyshop and was working on a falcon and the parts car they was useing he couldnt get the trunk lock to open so he was going to fire up the torch but he run out of gas so he drilled the lock and got trunk open only to find 16 real old pieces of dynamite it ws so old it had started coming apart and had stuck together.good thing he ran out of gas.the va state police brung their bomb trailer up and set it off
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 06-04-2003, 01:12 AM   #13
1969 GMC
1969 GMC's Avatar
lol I'm only 19, and underage drinking is illegal
i've never seen an old peel top beer or pop can, I'm a little too young for that...all of 'em I've seen are the usual pop and click variety.
scratch that, I have seen some of those old cans...i used to work a recycling center in scouts, and some weird people would bring those in by the truckload...makes you wonder where they've kept 'em all these years?
1969 GMC K2500
1996 Honda Accord
Old 06-04-2003, 01:14 AM   #14
krazy_texan
krazy_texan's Avatar
i found a cresent wrench and a playboy magazine from 1984 (coincidentaly the year i was born) under the seat
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 06-04-2003, 02:47 AM   #15
stateamind
And you call that a what?
stateamind's Avatar
I found ...
... a few pics of the p.o. girlfriend in her birthday suit (that means naked, for us slow people... lol) in one of my trucks. Those might be good for something some day. lol ... Other than than, just some misc tools, empty oil bottles, misc broken parts. Just the ussual stuff. oh, and the last truck I got probably had abt 100 pencils and pens everywhere. Thought that was strange.
stateamind is offline   Reply With Quote
Old 06-04-2003, 03:23 AM   #16
1969 GMC
1969 GMC's Avatar
lets see those pics!
1969 GMC K2500
1996 Honda Accord
Old 06-04-2003, 03:45 AM   #17
Seke69
Space Cadet
Seke69's Avatar
wow, what DIDN'T I find in my truck....
A Huge Nail Puller, pair of knee pads, eight pairs of unused rubber gloves, two axe handles, a hammer, two slotted screwdrivers, a 9/16 wrench, a new fuel pump, a brake lamp flasher, some other flasher, several gaskets, one spring jacket, half of a winter jacket, two stocking caps, a baseball bat, about ninety feet of various rope, a length of chain about 2', three spare tires, a five gallon pail, some safety goggles, and I can't remember anything else...
the strangest part is that aside from the bucket, and tires, all of this stuff was hidden ( under stuff, behind stuff, etc).
hey stateamind, let's see those pitures!
Seke69 is offline   Reply With Quote
Old 06-04-2003, 04:09 AM   #18
cheyenneman
I found a kISS ALIVE 8-track where the jack goes, about five bucks in change all over the place, some 22 shells and a PENTHOUSE from 1979 in the back of the seat. Wait until the guy replys about the dildo he found. its a funny story.
cheyenneman is offline   Reply With Quote
Old 06-04-2003, 05:14 AM   #19
jef5150
Inline 69
jef5150's Avatar
how much do you want for the 8 track???????
jef5150 is offline   Reply With Quote
Old 06-04-2003, 07:16 AM   #20
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
66 nova
I found some 66 Nova NOS rocker covers which I sold on ebay cause I need the money
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-04-2003, 08:56 AM   #21
Shane
Shane's Avatar
found 19 ... YES 19 .... half dollars in the cab corner pocket on the driver's side.
Shane is offline   Reply With Quote
Old 06-04-2003, 09:53 AM   #22
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
how bout a loaded GUN , & I found it 4 days after getting pulled over by the St Louis,Mo. POLICE & they had searched my truck & to think I had owned it only 3 weeks when this happened....joe
TooMany2count is offline   Reply With Quote
Old 06-04-2003, 10:07 AM   #23
Green72GMC
Green72GMC's Avatar
2 things of rolling paper shoved in the spring under the seat, a bag of chips, 10 or 12 old marb. cig packs, 4 bottes of brake fluid, an old wrench, A McDonalds toy, 2 or 3 eaten bags of chips, a stolen voltage tester thing, 2 busted 6x9's, 2 non working radios, and tons of leaves. All of this was under the seat except the wrench and brake fluid.
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 06-04-2003, 10:15 AM   #24
Randy70C-10
Randy70C-10's Avatar
I found an old picture of my truck in my truck.
Randy70C-10 is offline   Reply With Quote
Old 06-04-2003, 10:23 AM   #25
Riveted1
Tasty Cakes!
Riveted1's Avatar
Seke69, are you sure the PO wasn't a serial killer or something? Maybe a hitman for the mafia? LOL
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
