Old 11-25-2012, 03:14 AM   #1
AJII
AJII's Avatar
Hi Beam Indicator Problem...HELP :)
Recently installed a LMC Headlight Relay Harness on my truck. Junk.
It was wired completely wrong..Low were the highs, and never had all for on for Hi.
Well, got all that straighted out but now when the headlights are on dim, the Hi Beam indicator is on. Click to Hi, Indicator goes off
What wire(s) control the indicator?
It's an 85K10 with the Stacked Quads.
Thanks!
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 11-25-2012, 11:07 AM   #2
J Knight
J Knight's Avatar
Re: Hi Beam Indicator Problem...HELP :)
You need to swap the power leads from your factory harness to the relays. One lead is for the low beams and one is for the high beams, you must have crossed them during the install.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-25-2012, 02:45 PM   #3
bilfman
bilfman's Avatar
As night said, just reverse the leads for hi and low and it will be fine.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 11-25-2012, 07:09 PM   #4
AJII
AJII's Avatar
That worked! Thanks guys!
