Old 11-25-2012, 11:43 AM   #1
C10 Ad1CT
Rear end identification
Ok other than removing the diff cover, is there any way to tell what gear ratio my axle is and if it is a posi or not? Numbers maybe?
C10 Ad1CT is offline   Reply With Quote
Old 11-25-2012, 12:33 PM   #2
J kippin
J kippin's Avatar
Re: Rear end identification
did you try jacking it up and spinning the tire to see the ratio? mark the drive shaft mark the tire and spin the tire to get one full drive shaft revolution.Count how many times you spin the tire.
John
J kippin is offline   Reply With Quote
Old 11-25-2012, 02:27 PM   #3
HotRod C/10
HotRod C/10's Avatar
jack it up and roll the passenger side wheel, if the driver side moves in the same direction you have a posi (if it was not welded posi by the PO).
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-25-2012, 04:27 PM   #4
69GWC
Pull the cover and count the teeth and see if it has a posie or not, If you have not change the fluid on it for awhile it could use it anyway.
Plus if you have not done it who knows when it was done last.
69GWC is offline   Reply With Quote
Old 11-25-2012, 04:38 PM   #5
gearys 5600
gearys 5600's Avatar
There is numbers and letter codes on one of the axle tubes. I cant remember which one. I do remember it is about 3" from where the tube is welded to the center section, usually near the top of the tube.
The letter sequence will tell you what year, gear ratio, locker or non locker.
You will have to google the code or Im sure someone on here has a book that tells that info.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-25-2012, 07:04 PM   #6
southern parts
southern parts's Avatar
the id code is on the passenger side axle tube. the 70 -72 (wide housing ) rear ends will have a 3 letter code. the 67-69( narrow housing) will have a 2 letter code. some early 70 trucks will have a narrow housing with a 2 digit code.
southern parts is offline   Reply With Quote
Old 11-25-2012, 09:31 PM   #7
72 K20
72 K20's Avatar
Isn't this only on the Dana rear ends ?
72 K20 is offline   Reply With Quote
Old 11-25-2012, 10:13 PM   #8
gearys 5600
I dont know where you got that info.
Every G.M 10 bolt or 12 bolt, car or truck that I have seen has a code on the housing.
1956 chevy nomad
Old 11-26-2012, 12:49 AM   #9
72 K20
72 K20's Avatar
I did not know that the other companies stamped the axle tubes like Dana does.
My mistake, Sorry
Old 11-26-2012, 01:07 AM   #10
gearys 5600
My mistake, Sorry
No need to apologize..
I learn something new every time I am on this forum.
1956 chevy nomad
Old 11-26-2012, 06:35 AM   #11
bk2life
spin tire like said above. but x2 on pullin the cover and puttin in fresh gear oil..
bk2life is offline   Reply With Quote
Old 11-26-2012, 12:07 PM   #12
rpmgroup
I go with pulling the cover. I have found that many units have different gears then marked on the tube. (see the many ratio changes there on this forum)
rpmgroup is offline   Reply With Quote
Old 11-26-2012, 11:32 PM   #13
RipMeyer
RipMeyer's Avatar
Is there a metal tag attached to one of the cover bolts? If so its got all the info you need on it.
RipMeyer is offline   Reply With Quote
