11-25-2012, 01:50 PM | #1 |
79 c10 ls3 crate 4l80e trans but need a 12 bolt help plz
Hi im looking online at ls3 crates
http://www.crateenginedepot.com/LS3-...10590C943.aspx And a 4l80e trans http://www.gearstar.net/m/transmissi...d=639&catunid= But i need a 12 bolt but dont know how it would need to be built to match my truck with the efi ls3 and 4l80e and dont know where to get it built money is not a problem please let me know if u have any info or a better setup Posted via Mobile Device |
11-25-2012, 02:20 PM | #2 |
Re: 79 c10 ls3 crate 4l80e trans but need a 12 bolt help plz
Id check out Strange. An i wish i had your money tree. I stay in Arlington but from gp. Usually there on wkends visiting parents. When done with your truck would luv to check it out.
11-25-2012, 02:24 PM | #3 |
Im just young still with my parents only bill is paying them 200 a month for rent and i make around 2200 a month. I just bought a belltech suspension kit and plan to post pics as i get with each small project. Is strange near dallas or a website?
11-25-2012, 02:42 PM | #4 |
I have a 79 with a 4l80e running 32" tires , the minimum gear ratio that I would use would be 4.10. If you are wanting a bit more giver..., I would definitely not hesitate to go 4.56. Currently I have 3.73's and spin 1850 at 60, that is a little low in my opinion, I for sure would take 4.10 in a heart beat.
So that in mind you have some numerical data to crunch to where you want to be gear wise.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
11-25-2012, 02:47 PM | #5 |
Its a website strangeengineering. Maybe ill see you around i drive a red 84 long bed.
11-25-2012, 02:54 PM | #6 | |
11-25-2012, 02:58 PM | #7 |
11-25-2012, 03:09 PM | #8 |
Ya my 84 its my daily driver. No projects or pix on here though. Right now gathering parts to have front suspension rebuilt sanded an powder coated nxt month. Last yr had a 5.3 ls an built 700r4 put in. Maybe ill start takin pix an start some build threads soon
11-25-2012, 08:32 PM | #9 |
Axles....http://www.ringpinion.com/b2c/Produc..._Gear_and_Axle
Posi....http://www.ringpinion.com/b2c/Produc...and=Eaton_Posi 4:11 Gears....http://www.ringpinion.com/b2c/Produc...nd_Pinion_Sets 3:73 Gears....http://www.ringpinion.com/b2c/Produc...nd_Pinion_Sets Bearings/set-up kit....http://www.ringpinion.com/b2c/PartsL...RWD&DiffID=192 Forged 1350 Yoke....http://www.ringpinion.com/b2c/Produc..._Gear_and_Axle Wheel seals, Wheel bearings & gear oil....Buy Local. The gear ratio you need will depend on your tire height. If you need it assembled, PM me. |
11-25-2012, 08:47 PM | #10 |
So should i buy rims and tires after i do my suspension im replacing the suspension with belltech suspension kit i also bought spindals tie rods control arms and a front break kit i plan to do all that with my dad the get the rear then last 2 together trans and engine once a shop installs that ima do all the body myself its going to be gloss black everything else chrome. Also the rear you got going for me would it work with my stock th350 for now and my truck will be lowered 3 or 4 in the back idk if those are need to know things im just planning ahead.
Tags |
ls3 efi 4l80e |
