Old 11-25-2012, 02:12 PM   #1
cayce_brunswick-
Heater as
I know I need to put pictures on here and maybe I will soon but I mostly just wanted to tell everyone what I did Thursday night. It's finally starting to get cold here and I decided to fix the heat on my 70. I installed a new fan motor new heater core all new seals a new relay and lubed and painted both inside and outside airboxes when it was all out.
cayce_brunswick- is offline   Reply With Quote
Old 11-25-2012, 02:16 PM   #2
cayce_brunswick-
Re: Heater as
I should have mentioned this earlier but I forgot. I could really use a new heater controll for a non air truck and was wondering if anyone makes one with levers that are not the old pot metal. I would even take a used one for a driver if it was good shape. Just has to be driver quality. And the outside airbox on mine has a couple chips around the perimeter if anyone has a used one cheap.
Old 11-25-2012, 03:31 PM   #3
kaycee
kaycee's Avatar
Re: Heater as
$25 plus shipping.I think there is some out fit that makes steel ones but can't remember who
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-25-2012, 05:24 PM   #4
Tinkermc
Re: Heater as
sorry I thought I had a new 1 for you but it was with air.
Tinkermc is offline   Reply With Quote
Old 11-25-2012, 09:23 PM   #5
72 K20
72 K20's Avatar
Re: Heater as
Here ya' go !!
http://www.classicparts.com/1969-72-...ctinfo/68-476/
I rebuilt the controls in one of my C20's with this kit and it works great. The levers in this kit are steel, not pot metal. Make sure you clean and lube the cables,, it makes a big difference.
72 K20 is offline   Reply With Quote
Old 11-25-2012, 10:56 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Heater as
I used the kit also.I took the cables and locked on end of the center wire in a vise.Then I sprayed them with PB and worked them until they were sliding good.Then I coiled them and laid them in a oil drain pan with some oil.They' were then lubed with graphite and worked.13-14 years and they are still working good.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-26-2012, 09:57 AM   #7
Re: Heater as
Welcome to the site. Spend you're first $25 on a subscription to this site,then you can post a want to buy like you just did without violating the site rules you greed to
