11-25-2012, 11:51 PM | #1 |
5.3/t56 into a 72
So I'm really interested in swapping a 5.3 FI engine mated to an LS t56 in to 71/72. Bottom line is my 04 Silvy SS is eating me alive in fuel. I love te 67-72 body style so I figured that it would be a good alternative. But I have some questions?
1.will I get 20+ mpg high way w 3.73 gears? Will I need taller or Lower if not? 2. I want to do this CHEAP as possible, so can I use my stock gas tank? 3. Anyone have any tips with wiring, the 6 speed or just in general. Prob start collecting parts then sell the SS in the spring to fund the build Posted via Mobile Device
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
11-26-2012, 09:02 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 5.3/t56 into a 72
1. dont count on it. however, I would think if you tuned it right, it should get 18.
2. Yes you can, an external pump/filter, use a DBW motor with the returnless fuel rail. Custom Classic trucks magazine did an article about this ( maybe it was Classic Trucks mag) 3. If your going to need to purchase the stock harness, then dont, buy an aftermarket one, youll spend some $ but youll have what you need and nothing else. If your really mechanical, have a couple friends and of course all the parts, you can do the swap real fast, weekend maybe. Look here on the LSx board for tips and many posts of other folks' experience and costs. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-26-2012, 02:14 PM | #3 |
When picking out the T-56, keep in mind that they will have different 5th/6th gear ratios. 18 mpg might be doable with 3.73's, but 4.10's would be a better bet to get in the 20mpg range. If your not going to set up a T-56 right, its not worth the time and money just to say you have a 6th gear that you cant use.
You'll need the midshift kit unless you are going with custom bucket seats. The midshift kit is not difficult to install yourself if you have any mechanical ability. While your in there, you may as well swap out the 3/4 shift fork, install billet syncro keys, and replace any worn bearings and seals. |
11-26-2012, 02:19 PM | #4 |
I had wondered about the 4.11s bc of the super deep 6th. I plan on using seats out of a 03-07 Silverado and reinforcing the floor for the seat mounted seatbelts, so will I still need the midshift kit? Also with the 4.11s could I start in 2nd and only use 1st in "granny" situations? Thanks for the help bc I'd really love to do this for a daily driver soon
11-26-2012, 03:10 PM | #5 |
I am looking for a pair of the same seats, '03-'07 60/40 beanch with the flip up console. Based on the pictures i have seen, yes you will still need the midshift kit. Hurst offers several different shift levers to put the shift knob in just about any location. The T-56 has a reverse lockout, I used a shift knob with the buttom mounted on it to activate the reverse lockout.
A stock T-56 will put the shifter coming up just forward/through the hump under the bench in the 67-72's. I am running 4.10's behind my T-56 and first gear is not granny low. Its actually perfect with 28" tall tires. Also keep in mind that tire size is a variable that you can play with to fine tune things. You'll also have to do a hydraulic clutch, which isnt difficult. For me that was a big plus to the T-56 swap. Its a softer pedal, shorter pedal stroke, and eliminates the header issues with a mechanical clutch setup. Check out the T-56 rebuild and midshift install in the Engine/Drivetrain FAQ. Last edited by dznucks; 11-26-2012 at 03:17 PM. |
12-02-2012, 11:24 PM | #6 |
Dznucks, I see that you are local...I'd love to talk to you about this swap....I have been planning this swap myself..except I am thinking the 383 motor with the t56 is what I want. I am running 3.73s, but I want the power and more gears...plus the newness under the hood
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
12-03-2012, 02:58 PM | #7 |
meowMEOWmeowMEOW
I'm all for more swaps happening, but allow me to play the devil on this;
a 5.3 with stock cam and mileage-oriented tune in a lighter vehicle with the 3:73 and a tall tire (effectively making it even lower than 3:73), may net you over 20hwy, in a manual trans vehicle.... BUT You will never make back the cost of the swap in the difference in fuel....swapping engines (or in this case, building a whole different truck), will always be an exponential cost difference. You can do the math, but at $3.65 you can get over a thousand gallons of gas for the cost of your swap.
12-03-2012, 06:08 PM | #8 |
I have tried the T56 in my truck with 3.73 gears. I am going to swap these out to 4.?. first gear is higher (lower numerically) than a 4l60 I think that makes it hard on the clutch. With that in mind and the double overdrive I think it is a must to get a deeper gear. I was less than 1500 RPM at 65 to 70 MPH.
I think 20 is doable, I have a 5.3 turbocharged and cammed and I am shooting for 20 plus on the power tour. You are correct, you can never make up the money in fuel savings.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-03-2012, 06:51 PM | #9 | |
custom68 I am running 4.10's with a 28.5" tall tire and I use all of 1st gear. The factor you have to consider is the aerodynamics of the car they put these transmissions was alot better than these brick wall of trucks we drive. At the speeds needed to use 6th gear, on the interstate, the force of the air on the front of our trucks is alot greater than the comaro's and mustang it came out of. Bottom line is you need to build a motor that is going to be a torque monster off idle to 2000rpm, but not so big to be a fuel hog. The power curve of these milder stock 350's or LT/LS engines is not tuned to efficiently move a heavy truck at that low of an rpm. The 383 will be a good motor for a T-56, but they arent the best on fuel. |
12-03-2012, 08:50 PM | #10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=554542 Let me know. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-24-2013, 12:14 PM | #11 |
I have started this swap. I have a GTO t56, Dirty Dingo mounts and an LQ4. I have the motor where I want it, the shifter is ending up right at the middle of the space right behind the high hump. My question is if I want to get the shifter slightly forward without doing the mid shift mount kit, what are my options?
I see there is the B&M 45052 shifter for the f-body, as well as the offset lever: http://www.tickperformance.com/treme...y-cobra-viper/ What would you recommend? I just need about 2-3 inches forward Posted via Mobile Device
02-25-2013, 01:03 AM | #12 |
Anyone?
06-03-2013, 12:49 PM | #13 |
Well, my swap is finished.
6.0/6-speed. Posted via Mobile Device
06-03-2013, 08:07 PM | #14 |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
