Old 11-26-2012, 12:53 AM   #1
travz500
travz500's Avatar
would like to see some pics of rear mounted fuel tanks
Ok got some response on which tanks are out there but I would like to see some pictures of these tanks installed in the truck just trying to decide which tank I would like to purchase
travz500 is offline   Reply With Quote
Old 11-26-2012, 02:25 PM   #2
jimmydean
jimmydean's Avatar
Re: would like to see some pics of rear mounted fuel tanks
I am going with a generic tank from RCI. My bed will be raised, so I have some room to play with.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-26-2012, 02:57 PM   #3
TopFuel1966
TopFuel1966's Avatar
ECE tank.
TopFuel1966 is offline   Reply With Quote
Old 11-26-2012, 03:40 PM   #4
kieth
kieth's Avatar
Here is a link to the 84 blazer tank we used on my 66 gmc. This was a std carb fuel tank and it ended up with a in the tank fuel pump for my TBI 350 after we experienced lots of failures with in line pumps. cost of tank $200.00 sending unit and straps included (new) Kieth
http://kieth.smugmug.com/Trucks/66-G...5088&k=DrSmCmf
http://kieth.smugmug.com/Trucks/66-G...4496&k=7BvRxR3
kieth is offline   Reply With Quote
Old 11-26-2012, 10:07 PM   #5
oldtrux
oldtrux's Avatar
top fuel,that is a nice tank.i have been checking these out on ece's web site.do you have any pics to give me an idea of how low it hangs?thanx
oldtrux is offline   Reply With Quote
Old 11-26-2012, 10:43 PM   #6
lil_sahara450r
I have a aluminum tank from Performance online (I'm pretty positive that POL, ECE, and CPP all sell the exact same tank made by the same company) and I am very pleased with it. It doesn't hang down bad at all, even for a c-notched and bagged truck. If you can catch one on eBay from POL I believe that they are still $499 with the sending unit and everything else you need to install. Good deal for the $$ and they look awesome!
lil_sahara450r is offline   Reply With Quote
Old 11-26-2012, 11:09 PM   #7
pdxhall
pdxhall's Avatar
Here's mine. 64/65 falcon/mustang tank. $125.
pdxhall is offline   Reply With Quote
Old 11-27-2012, 12:17 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
16gal aluminum cell under bed. Filler cap under false bed rail.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-27-2012, 06:19 AM   #9
kerber63
kerber63's Avatar
I had a metal shop cut and break some 1/8" aluminum that a buddy welded up for me with a couple bungs and a threaded filler neck. 20 gallon capacity, modified one bed crossmember so it can sit a little above the frame.
kerber63 is offline   Reply With Quote
Old 11-27-2012, 07:22 PM   #10
TopFuel1966
Just for the record the ECE tanks are stainless steel, not aluminum. They cost a little more but well worth it.
Old 11-27-2012, 07:42 PM   #11
oldtrux
oldtrux's Avatar
topfuel,that's exactly the fit i'm looking for!hitch is cool too!thanks for posting the pics.
Old 11-27-2012, 08:38 PM   #12
travz500
travz500's Avatar
If you put these on a 4x4 am I am gonna have to remove the crossmember that is back there apparently the 2 wheel drives dont have that crossmember
Old 11-27-2012, 08:46 PM   #13
lil_sahara450r
Not trying to be a smartass, but why would you want a stainless tank over aluminum?
Old 11-27-2012, 10:24 PM   #14
TopFuel1966
The 2wd has a crossmember where the tank goes that needs to be removed. The ECE tank includes a new crossmember that bolts between the rear frame horns and creates a 3-sided box for the tank to mount in.
Old 11-27-2012, 10:29 PM   #15
TopFuel1966
Stainless is stronger than aluminum, but that's my opinion. If you feel comfortable with an aluminum tank in a potentially precarious location, by all means use it.
