GEARHEAD
Where is a blazer build sheet found?
Just curious. I know where the truck ones are found, but never found a blazer one. Where do they hide them?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Re: Where is a blazer build sheet found?
Good question.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
Possibly under drivers seat since that was the only standard seat. Or maybe in the dash? Ill post it as soon/ if I find one in my 69, the other blazers I have have been messed with.
Posted via Mobile Device |
![]() Join Date: Aug 2010
Reviving an old thread here... I was curious about the same thing and did some searching with no answer. I have a fairly untouched 72 jimmy and have searched high and low for a build sheet with no luck. It's a Freemont truck which leads me to believe it likely left the plant with a build sheet (if they treated the jimmys/blazers like the trucks.) My jimmy is covered with grease markings as well which leads me to believe that Freemont was consistent with their markings and patterns of leaving build sheets.
Anyone found a blazer build sheet yet? If so, where was it located?
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
You would think it would be somewhere in one of the front seats or even in the rear seat. Possibly in the dash. It seems surprising that no one has found one on a blazer or jimmy yet.
No build sheets for blazers. Not sure why though.
#7 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#8 | |
#9 | |
They were supposed to get tossed while cleaning up all the other debris left in the vehicle (other papers, extra screws, etc). Sometimes the vehicle was built up around the sheet such that it could not be removed, like inside a door panel, a seat cushion or on the floor with a screw shot through it or glue accidentally holding it down. In most cases, if you find a build sheet - someone was being lazy. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Nov 2013
the only thing I ever found was this tag under the rear seat cover and foam.....attached to the seat frame....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
