Old 11-26-2012, 12:12 PM   #1
'70GMCStep
350 missing
Looking for a advice on why engine is missing intermittently. Usually a miss and can be at acceleration or when smoothly running down road at constant rpm.
It will do it once, and then stop for maybe the whole trip. Running fresh gas, and haven't had this problem until recently. Hoping this is not oil leaking. Still watching carefully the oil pressure etc. Hopefully just a carb adjustment?
Thanks,
'70GMCStep
'65 Chevy C-10 bbw
'70 GMC Stepside swb
'70GMCStep is offline   Reply With Quote
Old 11-26-2012, 01:17 PM   #2
ChuckW
ChuckW's Avatar
Re: 350 missing
Check your plug wires and Dist. Cap. Are you using an HEI dist? (pointless) If not do a good tune up!
ChuckW is offline   Reply With Quote
Old 11-26-2012, 01:41 PM   #3
'70GMCStep
Re: 350 missing
Didn't think of the obvious. Thanks, I'll check on it.
Yea, running an HEI on the truck. Like a lot of people, I've got my dipstick right tight under heater box. Maybe pulled a wire off when putting dipstick back in.
'70GMCStep
'65 Chevy C-10 bbw
Old 11-26-2012, 01:44 PM   #4
ole dollor
ole dollor's Avatar
Re: 350 missing
like chuckw said...don't think its fuel, it in the firing some where, how long since a good tune up ,and check wires and cap and rotor...
ole dollor is offline   Reply With Quote
Old 11-26-2012, 02:08 PM   #5
glos55
glos55's Avatar
Re: 350 missing
I had that once...turned out to be a plug wire arcing on exhaust manifold. Found it looking at the motor at night.
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
