Old 11-26-2012, 02:39 PM   #1
Rockstargraphics
Dually Wheel Help
What is the exact process on putting dually front wheels on a 3/4 ton. I know I have to change a couple factory options but what? I don't wanna do wheel spacers if I don't have too. I want Dually front wheels on my truck but I have a 3/4 8 bolt.
Sorry for the noob post just want a good answer!
Rockstargraphics is offline   Reply With Quote
Old 11-26-2012, 03:04 PM   #2
C-10 simplex
Re: Dually Wheel Help
You may want to research and then possibly call these people.
http://www.arrowcraft.com/
2) There's no need to apologize----you spelt everything correctly and didn't use slang; i.e. "carby," "tranny" etc. That's a sign of someone who doesn't do it right.
C-10 simplex is offline   Reply With Quote
Old 11-26-2012, 03:21 PM   #3
C-10 simplex
P.S. an independent review:
http://www.ourelkhorn.itgo.com/drw.htm
Old 11-26-2012, 03:42 PM   #4
Rockstargraphics
Thank you for the post, I don't wanna buy a kit. I would like to use stuff from a square body.
Old 11-26-2012, 03:46 PM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
As far as the front goes, either spacers or get the DRW brake rotor/hub assembly. Frankly, spacers will be the easiest. The stress on the bearings would be the same whether you get the rotor/hub assembly or just spacers, and that is how most OEMs do their front hubs anyway these days with spacers.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 11-26-2012, 03:47 PM   #6
Leedogg
All you have to do is swap the front rotor assembly for a DRW front rotor. The DRW rotor has the offset built into it. The spindle/brakes are the same.
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 11-26-2012, 03:52 PM   #7
Rockstargraphics
I think wheel spacers aren't as strong compared to OEM
Old 11-26-2012, 03:53 PM   #8
Rockstargraphics
Perfect thank you very much, do you know if the 88 body style will fit or not? Maybe up to 91.
Old 11-26-2012, 04:01 PM   #9
GCncsuHD
GCncsuHD's Avatar
Except they are OEM...just not on this particular body style.
As long as they aren't cheaply made they can be as strong as or stronger than the OEM setup.
GM and Dodge both use the same hubs for 3/4 and 1 ton DRW and SRW trucks, both OEMs use bolt on spacers for the DRW applications on newer trucks. GM started this in 01, not sure when Dodge started, but I know 94+ trucks are that way. Not sure about Ford.
Just saying, it is an option, along with swapping the entire hub/rotor assembly, but generally, if your rotors are still good, the spacers are cheaper. If you need rotors, you might as well do rotor/hub assembly.
ΜΟΛΩΝ ΛΑΒΕ
Old 11-26-2012, 04:04 PM   #10
GCncsuHD
GCncsuHD's Avatar
73-87(91) body style uses a different part number than 88-98 body style. The part looks almost the same, but I am not sure of the actual difference. May be bearing size or rotor diameter.
ΜΟΛΩΝ ΛΑΒΕ
