11-26-2012, 04:03 PM | #1 |
What year rally wheels can I use?
They will go on my 63 with 2 1/2 inch drop spindles and 1 1/2 coils cut from spring in front. I need to know what year will work. I found 8 rally wheels 15x8 with 6 lug,,,,just what I need for 100 bucks and mid 80s.
11-26-2012, 04:09 PM | #2 |
Re: What year rally wheels can I use?
80'S is what you want, should fit fine.
11-26-2012, 05:49 PM | #3 |
Other year will fit also if they are not oem but aftermarket. Summit sells some and also Jegs or you can go to wheel vintiques. I would ask the dealer before you order.
11-26-2012, 05:56 PM | #4 |
67-72 parts collector,…
Search is your friend.
These are only 4 of the 10 threads I found just in the 60-66 section. http://67-72chevytrucks.com/vboard/s...t=rally+wheels http://67-72chevytrucks.com/vboard/s...t=rally+wheels http://67-72chevytrucks.com/vboard/s...t=rally+wheels http://67-72chevytrucks.com/vboard/s...t=rally+wheels
11-27-2012, 03:54 AM | #5 |
Here is pictures of the 6 lug truck rallys on my 62 ... and the 6 lug rallys I just put on ... Found rims on Craigslist locallly ..
